hi guys…
i want to use stable channel for my base system and i would like it to stay stable and only update for next release stable channel…but i also want to use latest app for my work…can i setup different channel inside 1 machine…1 stable channel for base system…1 unstable channel for working…if it posssible please show me how to make it?? thanks…
Yes you can.
There are multiple ways to do it. As you talk about channels, I won’t introduce flake
s but it is one solution exactly for it.
Using channels, you can register different name:
nix-channel --add unstable https://nixos.org/channels/nixpkgs-unstable
This way, you keep nixpkgs to, for example nixos-20.09 and you get a second one for unstable packages.
You can refer to them using <nixpkgs>
and <unstable>
in your nix files:
stable = import <nixpkgs> {};
unstable = import <unstable> {};
mkShell {
name = "amazing-shell";
buildInputs = [ stable.gcc unstable.vscode ];
If you mix a lot of programs and often, you can use an overlay.
Place the following file in .config/nixpkgs/overlay.nix
final: prev:
vscode = unstable.vscode;
From now vscode
will refer to the unstable one.
(Just using vscode as an example because stable releases usually lag behind programs like this that are frequently updating)
