I am hoping to enable maximize and minimize titlebar icons in GNOME and move them and the close button to the left of the titlebar by tweaking my home.nix file. I cannot find an option for this. I have looked for a dconf setting for it too and cannot find it.
What you could do is:
- Run
dconf dump / > old-conf.txt
- Change the setting in gnome manually in the GUI
- Run
dconf dump / > new-conf.txt
- Run
diff old-conf.txt new-conf.txt
This should tell you which dconf settings you need to put in your configration.
Thank you for your suggestion. It is a good idea. I just found the option in dconf that I needed though. Namely, it was "/org/gnome/desktop/wm"
and I needed to add:
"/org/gnome/desktop/wm/preferences" = {
button-layout = "close,maximize,minimize:menu"
to my home.nix
file to get the behaviour I wanted.
dconf watch /
will show changes as you make them.
