Aliases defined in `nix-shell`'s `shellHook` work with `--command` but not with `--run`
Given the following shell.nix
with import <nixpkgs> {};
pkgs.mkShell {
  pname = "just-testing";
  shellHook = ''
    echo AAAAAAAAAAAAAAAAAAA
    alias doit='echo DOING IT'
    echo BBBBBBBBBBBBBBBBBBB
    doit
    echo CCCCCCCCCCCCCCCCCCC
nix-shell --run 'echo ZZZZZZZZZZZZZ' gives
AAAAAAAAAAAAAAAAAAA
BBBBBBBBBBBBBBBBBBB
/nix/store/n4qv0ad1rg8rafppb4dh59n080m94bxy-stdenv-linux/setup: line 84: doit: command not found
CCCCCCCCCCCCCCCCCCC
ZZZZZZZZZZZZZ
while nix-shell --command 'echo ZZZZZZZZZZZZZ' gives
AAAAAAAAAAAAAAAAAAA
BBBBBBBBBBBBBBBBBBB
DOING IT
CCCCCCCCCCCCCCCCCCC
ZZZZZZZZZZZZZ
In other words, changing from --command to --run makes the alias defined in the shellHook disappear, (even though the echos indicate that the shellHook was executed).
What is the reason for this?
Bash does not expand aliases when in non-interactive mode. That’s why you see the difference in behaviour
