Does anyone have any experience working with docker and lisp using nix? I have this in my flake:
packages.dockerWIP = pkgs.dockerTools.buildImage {
name = "yap";
tag = "latest";
copyToRoot = pkgs.buildEnv {
name = "image-root";
paths = [ pkgs.sbcl pkgs.haproxy pkgs.clang ];
pathsToLink = [ "/bin" ];
runAsRoot = ''
#!${pkgs.runtimeShell}
config = {
Cmd = [];
I’m not totally sure how to use the quicklisp packaged in lisp, and when I tried to install with with curl the internet within the container didn’t work. Is there a way that I can set this up to use quicklisp within docker, or is there an external package that can work for this?
Thank you for your help
