I have a derivation that doesn’t seem to be respecting
—cores or —max-jobs / -j
is there other way to limit the number of cores available to the build?
You can use
stdenv.mkDerivation {
enableParallelBuilding = false;
on a per-derivation basis. Otherwise you can try setting the NIX_BUILD_CORES
environment variable.
Neither of those worked, probably because these derivations are being built from a nix-shell, rather nix-build.
but thanks anyway for your efforts.
You should find out which derivation exactly this comes from. Maybe there is a build script that hardcodes something like make -j 4
or so which is obviously not caught by any of Nix’s mechanisms.
