I’m trying to build backscrub but I’m at an impasse.
NixOS:master
← pasqui23:backscrub
opened 12:01PM - 01 Nov 21 UTC
Thanks a lot if you do!
###### Motivation for this change
A virtual background program for linux
###### Things done
Building fails with
nix log /nix/store/k4yl5pz54qk1bq2k1xpn0w029pa78f8n-backscrub-0.3.0.drv
@nix { "action": "setPhase", "phase": "unpackPhase" }
unpacking sources
unpacking source archive /nix/store/q4cc18jiamzz50i98anhl90hwsyrb4h3-source
source root is source
@nix { "action": "setPhase", "phase": "patchPhase" }
patching sources
/build/source/tensorflow /build/source
patching file tensorflow/lite/tools/make/Makefile
Hunk #1 succeeded at 139 with fuzz 1 (offset -1 lines).
Hunk #1 succeeded at 138 with fuzz 2 (offset -1 lines).
/build/source
@nix { "action": "setPhase", "phase": "configurePhase" }
configuring
fixing cmake files...
cmake flags: -DCMAKE_FIND_USE_SYSTEM_PACKAGE_REGISTRY=OFF -DCMAKE_FIND_USE_PACKAGE_REGISTRY=OFF -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_BUILD_TYPE=Release -DCMAKE_SKIP_BUILD_RPATH=ON -DBUILD_TESTING=OFF -DCMAKE_INSTALL_LOCALEDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/share/locale -DCMAKE_INSTALL_LIBEXECDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/libexec -DCMAKE_INSTALL_LIBDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/lib -DCMAKE_INSTALL_DOCDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/share/doc/backscrub -DCMAKE_INSTALL_INFODIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/share/info -DCMAKE_INSTALL_MANDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/share/man -DCMAKE_INSTALL_OLDINCLUDEDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/include -DCMAKE_INSTALL_INCLUDEDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/include -DCMAKE_INSTALL_SBINDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/sbin -DCMAKE_INSTALL_BINDIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/bin -DCMAKE_INSTALL_NAME_DIR=/nix/store/lv5ds11qy0himqxy83i2pdvrm1cfdmlx-backscrub-0.3.0/lib -DCMAKE_POLICY_DEFAULT_CMP0025=NEW -DCMAKE_OSX_SYSROOT= -DCMAKE_FIND_FRAMEWORK=LAST -DCMAKE_STRIP=/nix/store/hy3lz2vfv9qq2v5jz9nzlx6mmiaq79rj-binutils-2.35.1/bin/strip -DCMAKE_RANLIB=/nix/store/hy3lz2vfv9qq2v5jz9nzlx6mmiaq79rj-binutils-2.35.1/bin/ranlib -DCMAKE_AR=/nix/store/hy3lz2vfv9qq2v5jz9nzlx6mmiaq79rj-binutils-2.35.1/bin/ar -DCMAKE_C_COMPILER=gcc -DCMAKE_CXX_COMPILER=g++ -DCMAKE_INSTALL_PREFIX=/build/source/tensorflow/tensorflow/lite/tools/make/downloads
-- The CXX compiler identification is GNU 10.3.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /nix/store/qvv5y4fx4x879rbsbs4g27mypl9wxbb9-gcc-wrapper-10.3.0/bin/g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Could NOT find Git (missing: GIT_EXECUTABLE)
Version: v0.2.0-no-git
-- Found OpenCV: / (found version "4.5.2") found components: core imgproc imgcodecs video videoio highgui
-- The C compiler identification is GNU 10.3.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /nix/store/qvv5y4fx4x879rbsbs4g27mypl9wxbb9-gcc-wrapper-10.3.0/bin/gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
CMake Error at /nix/store/p1lk3bb1wzyn5v3nw8nyxrc44iy60vwk-cmake-3.19.7/share/cmake-3.19/Modules/ExternalProject.cmake:2542 (message):
error: could not find git for clone of abseil-cpp-populate
Call Stack (most recent call first):
/nix/store/p1lk3bb1wzyn5v3nw8nyxrc44iy60vwk-cmake-3.19.7/share/cmake-3.19/Modules/ExternalProject.cmake:3430 (_ep_add_download_command)
CMakeLists.txt:13 (ExternalProject_Add)
-- Configuring incomplete, errors occurred!
See also "/build/source/build/_deps/abseil-cpp-subbuild/CMakeFiles/CMakeOutput.log".
CMake Error at /nix/store/p1lk3bb1wzyn5v3nw8nyxrc44iy60vwk-cmake-3.19.7/share/cmake-3.19/Modules/FetchContent.cmake:977 (message):
CMake step for abseil-cpp failed: 1
/nix/store/p1lk3bb1wzyn5v3nw8nyxrc44iy60vwk-cmake-3.19.7/share/cmake-3.19/Modules/FetchContent.cmake:1118:EVAL:2 (__FetchContent_directPopulate)
/nix/store/p1lk3bb1wzyn5v3nw8nyxrc44iy60vwk-cmake-3.19.7/share/cmake-3.19/Modules/FetchContent.cmake:1118 (cmake_language)
tensorflow/tensorflow/lite/tools/cmake/modules/OverridableFetchContent.cmake:531 (FetchContent_Populate)
tensorflow/tensorflow/lite/tools/cmake/modules/abseil-cpp.cmake:34 (OverridableFetchContent_Populate)
tensorflow/tensorflow/lite/tools/cmake/modules/absl-config.cmake:18 (include)
tensorflow/tensorflow/lite/CMakeLists.txt:128 (find_package)
See also "/build/source/build/CMakeFiles/CMakeOutput.log".
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] For non-Linux: Is `sandbox = true` set in `nix.conf`? (See [Nix manual](https://nixos.org/manual/nix/stable/#sec-conf-file))
- [ ] Tested via one or more NixOS test(s) if existing and applicable for the change (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))
- [ ] Tested compilation of all packages that depend on this change using `nix-shell -p nixpkgs-review --run "nixpkgs-review wip"`
- [ ] Tested execution of all binary files (usually in `./result/bin/`)
- [21.11 Release Notes (or backporting 21.05 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2111-release-notes)
The problem is that its source expects that the source for tensorflow-lite, including any CMake files, is in the git submodule and any try to build it fails.
And yes I’ve tried “cp -a${tensorflow-lite}/include tensorflow” and it fails as the sources do not include the appropriate CMakeFiles.
