Big Sur & frameworks issue
I upgraded from Catalina to Big Sur, and my rust code is not linking properly:
  = note: ld: framework not found Security
          clang-7: error: linker command failed with exit code 1 (use -v to see invocation)
I already have Security framework in buildInputs:
    buildInputs = [ rust ] ++ (
       stdenv.lib.optionals stdenv.isDarwin [
         frameworks.Security
         frameworks.CoreServices
         frameworks.CoreFoundation
         frameworks.Foundation
         frameworks.AppKit
Also I am setting the NIX_LDFLAGS:
    shellHook = (
      if pkgs.stdenv.isDarwin then
            export NIX_LDFLAGS="-F${frameworks.AppKit}/Library/Frameworks -framework AppKit -F${frameworks.Security}/Library/Frameworks -framework Security -F${frameworks.CoreServices}/Library/Frameworks -framework CoreServices -F${frameworks.CoreFoundation}/Library/Frameworks -framework CoreFoundation $NIX_LDFLAGS";
      else
      export LD_LIBRARY_PATH=$(rustc --print sysroot)/lib:${stdenv.cc.cc.lib}/lib:$LD_LIBRARY_PATH:/System/Library/Frameworks/;
      export LIBCLANG_PATH="${llvmPackages.libclang}/lib"
      export ZDOTDIR=`pwd`;
      export HISTFILE=~/.zsh_history
      export CARGO_TARGET_DIR=`pwd`/target-nix
      echo "Using ${python38.name}, ${elmPackages.elm.name}, ${rust.name} and ${postgresql_12.name}."
      unset MACOSX_DEPLOYMENT_TARGET
Worked well on Catalina. Any pointers?
for big sur, you need to be following the unstable branch, the big sur changes haven’t been tested or backported yet.
Can you confirm this is still the case?
I believe so, as there was many changes. IIRC, the backport PR was closed because of other changes were missing and hard to capture.
Any progress @jonringer ?
I’ve been following https://github.com/NixOS/nix/issues/4621. Is there any issue covering this?
Got similar issue, details here Dev environment setup failure with MacOS · Issue #37 · holochain/launcher · GitHub
Any updates?
