I’m trying to make a package for a C project of mine, but I’m having trouble getting the code to build on NixOS.
As an example, I have the following CMakeLists.txt
cmake_minimum_required(VERSION 2.8.12)
project( test )
find_package(GTK2 2.6 REQUIRED gtk)
if(GTK2_FOUND)
message( STATUS "GTK-2 found")
else()
message(FATAL_ERROR "GTK-2 not found")
endif()
My default.nix
is
{mkDerivation, cmake, gtk2, pkg-config} :
mkDerivation {
name = "test";
src = ./.;
nativeBuildInputs = [ cmake pkg-config ];
buildInputs = [ gtk2 ];
and I also have a shell.nix
to make things easier:
with import <nixpkgs> {};
stdenv.mkDerivation {
name = "test";
buildInputs = [
(callPackage ./default.nix {mkDerivation = stdenv.mkDerivation ; })
When calling nix-shell
I obtain the following error:
/nix/store/cywgm8c8r367wx0jj51z4isl58nvp4d3-test.drv
building '/nix/store/cywgm8c8r367wx0jj51z4isl58nvp4d3-test.drv'...
unpacking sources
unpacking source archive /nix/store/lp9pxrrzh6rxyiamh8dqvnpj7r407133-gtk-test
source root is gtk-test
patching sources
configuring
fixing cmake files...
cmake flags: -DCMAKE_FIND_USE_SYSTEM_PACKAGE_REGISTRY=OFF -DCMAKE_FIND_USE_PACKAGE_REGISTRY=OFF -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DCMAKE_INSTALL_LOCALEDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/share/locale -DCMAKE_INSTALL_LIBEXECDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/libexec -DCMAKE_INSTALL_LIBDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/lib -DCMAKE_INSTALL_DOCDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/share/doc/test -DCMAKE_INSTALL_INFODIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/share/info -DCMAKE_INSTALL_MANDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/share/man -DCMAKE_INSTALL_OLDINCLUDEDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/include -DCMAKE_INSTALL_INCLUDEDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/include -DCMAKE_INSTALL_SBINDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/sbin -DCMAKE_INSTALL_BINDIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/bin -DCMAKE_INSTALL_NAME_DIR=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test/lib -DCMAKE_POLICY_DEFAULT_CMP0025=NEW -DCMAKE_OSX_SYSROOT= -DCMAKE_FIND_FRAMEWORK=LAST -DCMAKE_STRIP=/nix/store/3d9zjv5vaqjxb9kwbdqsd194alwm97x1-gcc-wrapper-11.3.0/bin/strip -DCMAKE_RANLIB=/nix/store/3d9zjv5vaqjxb9kwbdqsd194alwm97x1-gcc-wrapper-11.3.0/bin/ranlib -DCMAKE_AR=/nix/store/3d9zjv5vaqjxb9kwbdqsd194alwm97x1-gcc-wrapper-11.3.0/bin/ar -DCMAKE_C_COMPILER=gcc -DCMAKE_CXX_COMPILER=g++ -DCMAKE_INSTALL_PREFIX=/nix/store/jkpp4hvcwrndgznf75nvbbbxr5jnziaa-test
-- The C compiler identification is GNU 11.3.0
-- The CXX compiler identification is GNU 11.3.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /nix/store/3d9zjv5vaqjxb9kwbdqsd194alwm97x1-gcc-wrapper-11.3.0/bin/gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /nix/store/3d9zjv5vaqjxb9kwbdqsd194alwm97x1-gcc-wrapper-11.3.0/bin/g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Some or all of the gtk libraries were not found. (missing: GTK2_GDKCONFIG_INCLUDE_DIR GTK2_GLIBCONFIG_INCLUDE_DIR)
CMake Error at CMakeLists.txt:9 (message):
GTK-2 not found
-- Configuring incomplete, errors occurred!
See also "/build/gtk-test/build/CMakeFiles/CMakeOutput.log".
error: builder for '/nix/store/cywgm8c8r367wx0jj51z4isl58nvp4d3-test.drv' failed with exit code 1;
last 10 log lines:
> GTK-2 not found
For full logs, run 'nix log /nix/store/cywgm8c8r367wx0jj51z4isl58nvp4d3-test.drv'.
It seems cmake find some parts of GTK2, but not all, and so it fails on the if(GTK2_FOUND)
instead of on find_package(GTK2 2.6 REQUIRED gtk)
(which is where it fails if I remove gtk2
from buildInputs
Am I doing something wrong in cmake
? Or do I need to install additional packages other than gtk2
? Any help or pointers would be appreciated.
