I am currently trying to create an environment that supports a certain build process.
It must support
- building statically linked binaries from C and C++ sources
- building dynamically linked binaries from C and C++ sources
My minimal breaking example looks like this:
#include <stdio.h>
int
main ()
FILE *f = fopen ("conftest.out", "w");
return ferror (f) || fclose (f) != 0;
return 0;
and
#include <cstdlib>
#include <stdio.h>
int
main ()
return 0;
If I have only the gcc
package in my environment I can build dynamic C and C++ binaries, but static linking does not work as the linker does not find a static libc.
By including glibc.static
I can build static C binaries, but the dynamically linked variant crashes with a segmentation fault in this line:
Dump of assembler code for function __libc_start_main_impl:
0x0000000000405720 <+0>: endbr64
0x0000000000405724 <+4>: push %r15
0x0000000000405726 <+6>: lea 0x1(%rsi),%eax
0x0000000000405729 <+9>: push %r14
0x000000000040572b <+11>: cltq
0x000000000040572d <+13>: push %r13
0x000000000040572f <+15>: push %r12
0x0000000000405731 <+17>: mov %rdx,%r12
0x0000000000405734 <+20>: push %rbp
0x0000000000405735 <+21>: mov %esi,%ebp
0x0000000000405737 <+23>: push %rbx
0x0000000000405738 <+24>: sub $0xd8,%rsp
0x000000000040573f <+31>: mov %rdi,0x40(%rsp)
0x0000000000405744 <+36>: lea (%rdx,%rax,8),%rdi
0x0000000000405748 <+40>: mov 0x110(%rsp),%rax
0x0000000000405750 <+48>: mov %r9,0x48(%rsp)
0x0000000000405755 <+53>: mov %rdi,0x9c5c4(%rip) # 0x4a1d20 <environ>
=> 0x000000000040575c <+60>: mov %rax,0x94ffd(%rip) # 0x49a760 <__libc_stack_end>
When I additionally include the package glibc
I can build static and dynamic C sources, but C++ does not work anymore due to the following error:
In file included from test.cpp:1:
/nix/store/b7hvml0m3qmqraz1022fwvyyg6fc1vdy-gcc-12.2.0/include/c++/12.2.0/cstdlib:75:15: fatal error: stdlib.h: No such file or directory
75 | #include_next <stdlib.h>
compilation terminated.
Does anyone know how I can build a working environment for this (quite simple imho) use case?
