Building maven application with fixed output derivation fails
I’m trying to package an Eclipse application built with maven 3.6 by using fixed output derivation (Packaging a Maven application with Nix | Farid Zakaria’s Blog).
{ lib
, stdenv
, fetchFromGitHub
, fetchurl
# Build
, eclipse-sdk
, maven3
, openjdk8_headless
# Install
, makeWrapper #
, util-linux # find
, coreutils # cp, install
# Run-time
, glibc # libc6
, atk # libatk
, gtk2 # libgtk2
, cairo # libcairo
, glib # libglib2
, webkitgtk # libwebkitgtk-1.0
, libXtst # libxtst6
, gcc # stdc++ 6
, swt #
, jre8 # java 8
, freetype # libfreetype.so.6
, perl # plugins/**/bin/{antRun.pl,runant.pl,...}
, python # plugins/**/bin/{runant.py,...}
with lib;
  pname = "modelio";
  version = "4.1.0";
  src = fetchFromGitHub {
    owner = "ModelioOpenSource";
    repo = "${pname}";
    rev = "v${version}";
    sha256 = "02hd2ldslppby0l4qzb8nr17dnzckir4rjp3bri6slj6422kfds1";
  maven360 = maven3.overrideAttrs (oldAttrs: rec {
    pname = "apache-maven";
    version = "3.6.0";
    src = fetchurl {
      url =
        "https://archive.apache.org/dist/maven/maven-3/${version}/binaries/${pname}-${version}-bin.tar.gz";
      sha256 = "0ds61yy6hs7jgmld64b65ss6kpn5cwb186hw3i4il7vaydm386va";
  # Perform fake build to a fixed-output derivation of the files downloaded from
  # maven central.
  dependencies = stdenv.mkDerivation {
    inherit src;
    name = "${pname}-${version}-dependencies";
    nativeBuildInputs = [ maven360 openjdk8_headless util-linux ];
    buildPhase = ''
      while mvn \
        --define maven.repo.local=$out/.m2 \
        --define maven.wagon.rto=5000 \
        package; \
        [ $? = 1]; do
          printf "%s\n" "Timeout, restart maven to continue downloading"
        done
    # Keep only *.{pom,jar,sha1,nbm}, and delete all ephemeral files with
    # lastModfied timestamps inside.
    installPhase = ''
      find $out/.m2 -type f \
        -regex \
        '.+\(\.lastUpdated\|resolver-status\.properties\|_remote\.repositories\)' \
        -delete
    outputHashAlgo = "sha256";
    outputHashMode = "recursive";
    outputHash = "1c9fym6fhk0cyxrzb5q5dywns1sdnfva7qr80ip8dsgdyzj9i1az";
in stdenv.mkDerivation rec {
  inherit pname version src dependencies;
  nativeBuildInputs = [ eclipse-sdk maven360 openjdk8_headless ];
  buildInputs = [
    glibc
    atk
    gtk2
    cairo
    glib
    webkitgtk
    libXtst
    gcc
    swt
    jre8
    freetype
    perl
    python
  # patches = [ ./pom.xml.patch ];
  buildPhase = ''
    # 'maven.repo.local' must be writable, so copy it out of the nix store.
    cp --archive ${dependencies}/.m2 ./ && chmod --recursive +w .m2
    pwd
    ls -la
    ls -la .m2
    mvn --offline \
      --file AGGREGATOR/pom.xml \
      --define maven.repo.local=$(pwd)/.m2 \
      package
  installPhase = ''
    mkdir --parents $out/bin
    install -D --mode=644 \
      "$src/products/target/products/org.modelio.product/linux/gtk/x86_64/Modelio 4.1/*" \
      --target $out
    ln --symbolic $out/usr/lib/modelio-open-source4.1/modelio $out/bin/modelio
    ln --symbolic $out/usr/lib/modelio-open-source4.1/modelio.sh $out/bin/modelio.sh
    rm --recursive --force $out/usr/lib/modelio-open-source4.1/jre
    ln --symbolic ${jre8.home}/jre $out/usr/lib/modelio-open-source4.1/jre
    rm --recursive --force $out/lib
    ln --symbolic ${dependencies}/.m2 $out/lib
  meta = with lib; {
    description = "Free, extensible modeling environment for UML and BPMN.";
    homepage = "https://www.modelio.org";
    changelog =
      "https://github.com/ModelioOpenSource/Modelio/releases/tag/v4.1.0";
    platforms = [ "x86_64-linux" ];
    mainProgram = "modelio";
    hydraPlatforms = [ ];
    license = licenses.gpl3;
However, the build initially fails trying to get tycho.
[ERROR] Internal error: java.lang.RuntimeException: Could not instantiate required component: com.google.inject.ProvisionException: Unable to provision, see the following errors:
[ERROR]
[ERROR] 1) Error notifying InjectionListener org.eclipse.sisu.plexus.PlexusBeanBinder@236134a1 of org.eclipse.tycho.p2.resolver.P2DependencyResolver.
[ERROR]  Reason: java.lang.RuntimeException: org.apache.maven.MavenExecutionException: Could not resolve artifact for Tycho's OSGi runtime
[ERROR]   while locating org.eclipse.tycho.p2.resolver.P2DependencyResolver
[ERROR]   at ClassRealm[extension>org.eclipse.tycho:tycho-maven-plugin:1.5.0, parent: sun.misc.Launcher$AppClassLoader@677327b6] (via modules: org.eclipse.sisu.wire.WireModule -> org.eclipse.sisu.plexus.PlexusBindingModule)
[ERROR]   while locating org.eclipse.tycho.core.DependencyResolver annotated with @com.google.inject.name.Named(value=p2)
[ERROR]
[ERROR] 1 error
[ERROR]       role: org.eclipse.tycho.core.DependencyResolver
[ERROR]   roleHint: p2: Missing:
[ERROR] ----------
[ERROR] 1) org.eclipse.tycho:tycho-bundles-external:zip:1.5.0
[ERROR]
[ERROR]   Try downloading the file manually from the project website.
[ERROR]
[ERROR]   Then, install it using the command:
[ERROR]       mvn install:install-file -DgroupId=org.eclipse.tycho -DartifactId=tycho-bundles-external -Dversion=1.5.0 -Dpackaging=zip -Dfile=/path/to/file
[ERROR]
[ERROR]   Alternatively, if you host your own repository you can deploy the file there:
[ERROR]       mvn deploy:deploy-file -DgroupId=org.eclipse.tycho -DartifactId=tycho-bundles-external -Dversion=1.5.0 -Dpackaging=zip -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
[ERROR]
[ERROR] ----------
[ERROR] 1 required artifact is missing.
[ERROR]
[ERROR] for artifact:
[ERROR]   org.eclipse.tycho:tycho-bundles-external:zip:1.5.0
[ERROR]
[ERROR] from the specified remote repositories:
[ERROR]   central (https://repo.maven.apache.org/maven2, releases=true, snapshots=false)
[ERROR] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: Could not instantiate required component
Any idea?
I think it might be an issue with the fixed output derivation because I’ve wrote a shell.nix, and it works for building.
  maven360 = pkgs.maven3.overrideAttrs (oldAttrs: rec {
    version = "3.6.0";
    src = pkgs.fetchurl {
      url = "https://archive.apache.org/dist/maven/maven-3/${version}/binaries/${pname}-${version}-bin.tar.gz";
  pkgs = import <nixpkgs> { };
in with pkgs;
mkShell {
    eclipses.eclipse-sdk
    maven360
    openjdk8_headless
    autoPatchelfHook
  buildInputs = [
    glibc
    atk
    gtk2
    cairo
    glib
    webkitgtk
    xorg.libXtst
    gcc
    swt
    jre8
    freetype
    perl
    python
  JAVA_HOME = openjdk8_headless.home;
  LANG = "C.UTF-8";
  LC_ALL = "C.UTF-8";
if anyone can give any suggestion i’d be grateful
:frowning_face: :zzz: :sob: :zzz: :frowning_face: :zzz: :sob: :zzz: :frowning_face: :zzz: :sob: :zzz: :frowning_face: :zzz: :sob: :zzz: :frowning_face: :zzz: :sob: :zzz: :frowning_face: :zzz: :sob: :zzz:
