Bulding GPAW on NixOS: issues with C++ toolchain
Hi all, I just started my adventure on NixOS and I am trying to get my environment up and running.
I am interested in installing GPAW on my system, I do not care too much about all the dependencies that can improve performance, so the list of dependencies reduces to:
  • Python 3.6 or later
  • NumPy 1.9 or later (base N-dimensional array package)
  • SciPy 0.14 or later (library for scientific computing)
  • ASE 3.18.0 or later (atomic simulation environment)
  • a C-compiler
  • LibXC 3.x or 4.x
  • BLAS library
I created shell.nix with the following content (based on an example on nixos.org):
{ pkgs ? import <nixpkgs> {}
pkgs.mkShell {
  name="dev-environment";
  buildInputs = [
    pkgs.python3
    pkgs.gcc
    pkgs.blas
    pkgs.libxc
   shellHook = ''
     echo "Start developing..."
From the nix-shell I enter a Python venv I already created and then run pip install gpaw that installs the needed Python dependencies as well.
It actually complete the setup without any issue, but when I run gpaw test I obtain the following error:
plenty of stuff that redirects to the final error in a scipy function
ImportError: libstdc++.so.6: cannot open shared object file: No such file or directory
I am quite sure I am overlooking something obvious, but I cannot find the cause of this issue, probably because of my limited experience with NixOS.
Any hint is greatly appreciated!
nixpkgs will only export glibc by default, libstdc++.so.6 is provided by gcc, not glibc.
  shellHook = ''
     LD_LIBRARY_PATH=${lib.makeLibraryPath [ pkgs.stdenv.cc.cc.lib ]};
you could also use gcc.cc.lib, but generally people will pull it out of stdenv to ensure library coherence in the case that cc provided by stdenv differs.
Thank for the tip!
I tried but it did not find lib, so I modified it into:
   shellHook = ''
     LD_LIBRARY_PATH=${pkgs.stdenv.lib.makeLibraryPath [ pkgs.stdenv.cc.cc.lib ]};
But it still returns the same error about libstdc++.so.6.
>>> echo $LD_LIBRARY_PATH
/nix/store/danv012gh0aakh8xnk2b35vahklz72mk-gcc-9.2.0-lib/lib
I solved the problem by using the Python packages provided by NixOS:
{ pkgs ? import <nixpkgs> {},
pkgs.mkShell {
  buildInputs = [
    pkgs.python3
    pkgs.python3Packages.numpy
    pkgs.python3Packages.scipy
    pkgs.python3Packages.matplotlib
    pkgs.python3Packages.six
    pkgs.python3Packages.pillow
    pkgs.python3Packages.kiwisolver
    pkgs.python3Packages.setuptools
    pkgs.python3Packages.wheel
    pkgs.python3Packages.pytest
    pkgs.python3Packages.spglib
    pkgs.python3Packages.flask
    pkgs.python3Packages.psycopg2
    pkgs.gcc
    pkgs.blas
    pkgs.libxc
    pkgs.openmpi
   shellHook = ''
     echo "Activating Python venv..."
     source "$HOME/master-project/venv/bin/activate"
     export GPAW_SETUP_PATH="$HOME/master-project/gpaw-dataset/gpaw-setups-0.9.20000"
     export PYTHONPATH="$HOME/master-project/ase:$PYTHONPATH"
     export PATH="$HOME/master-project/ase/bin:$PATH"
     echo "Done."
The file contains some additional setup as well, just to set everything up in one step.
Maybe this is not a clean solution, but it works (finger crossed).
