Call for help to migrate packages from `xlibsWrapper`
nixpkgs has an old xlibsWrapper package that does not do anything on it’s own except for re-exporting a few other X11 packages:
  # Avoid using this. It isn't really a wrapper anymore, but we keep the name.
  xlibsWrapper = callPackage ../development/libraries/xlibs-wrapper {
    packages = [
      freetype fontconfig xorg.xorgproto xorg.libX11 xorg.libXt
      xorg.libXft xorg.libXext xorg.libSM xorg.libICE
There are about at least 80 packages that still use this aggregated package. Here is an incomplete list of packages that se it: Deprecate and remove `xlibsWrapper` · Issue #194054 · NixOS/nixpkgs · GitHub
Typical fix should replace xlibsWrapper for actually used libraries. Here is a pulseaudio example: pulseaudio: use xorg.* packages directly instead of xlibsWrapper indi… by trofi · Pull Request #194110 · NixOS/nixpkgs · GitHub. Note how in this case pulseaudio does not depend on fonts packages anymore (yay!).
Another fun fix is perlPackages.X11Protocol where none of libraries are used at all: perlPackages.X11Protocol: drop unused pkgs.xlibsWrapper build input by trofi · Pull Request #194184 · NixOS/nixpkgs · GitHub.
It takes a while to audit each package. If you are into that kind of things please grab one or a few, port it over and link PR in Deprecate and remove `xlibsWrapper` · Issue #194054 · NixOS/nixpkgs · GitHub.
Thank you!
Today we lost last user of xlibsWrapper: poetry2nix. Now we can finally remove it: xlibsWrapper: remove deprecated and now unused wrapper package by trofi · Pull Request #207938 · NixOS/nixpkgs · GitHub
Thanks all!
