Changing kernel: The kernel module and the userspace tooling versions are not matching
I want to try an older version of the kernel (6.12.34 instead of 6.12.60), so I added in my flake:
boot.kernelPackages = inputs.nixpkgsKernelThatWorked.legacyPackages.${pkgs.system}.linuxPackages_6_12;
but when I compile, I get an error:
The kernel module and the userspace tooling versions are not matching, this is an unsupported usecase.
or more precisely:
┏━ 1 Errors:
┃ error:
┃        … while calling the 'head' builtin
┃          at /nix/store/hv1dx0bah4m1mw2asfrg29wl17by9ngd-source/lib/attrsets.nix:1696:13:
┃          1695|           if length values == 1 || pred here (elemAt values 1) (head values) then
┃          1696|             head values
┃          1697|           else
┃        … while evaluating the attribute 'value'
┃          at /nix/store/hv1dx0bah4m1mw2asfrg29wl17by9ngd-source/lib/modules.nix:1118:7:
┃          1117|     // {
┃          1118|       value = addErrorContext "while evaluating the option `${showOption loc}':" value;
┃          1119|       inherit (res.defsFinal') highestPrio;
┃        … while evaluating the option `system.build.toplevel':
┃        … while evaluating definitions from `/nix/store/hv1dx0bah4m1mw2asfrg29wl17by9ngd-source/nixos/modules/system/activation/top-level.nix':
┃        (stack trace truncated; use '--show-trace' to show the full, detailed trace)
┃        error:
┃        Failed assertions:
┃        - The kernel module and the userspace tooling versions are not matching, this is an unsupported usecase.
┗━ ∑ ⚠ Exited with 1 errors reported by nix at 19:24:44 after 2s
I suspect ZFS to be the userspace tool that produces this version mismatch, but I don’t know how to fix this. Any ideas?
EDIT
I tried this (unfree needed as I use nvidia… even if I have open = true):
  # I get issues with latest kernels with nvidia, let's used one that used to work
  boot.kernelPackages = (import inputs.nixpkgsKernelThatWorked {
    inherit system; config = {allowUnfree = true;};}
  ).linuxPackages_6_12;
  boot.zfs.package = (import inputs.nixpkgsKernelThatWorked {
  ).zfs;
and it seems to work so far (at least it compiles…). Is it the recommanded solution? How am I supposed to match the versions here between zfs and linuxPackages (I think here I’m just lucky that they match since this is the default kernel in this nixpkgs)?
Any reference to kernels should always be based off config.boot.kernelPackages. I assume you have a bad value in boot.zfs.package or boot.zfs.modulePackage, currently.
