I am working on a C++ project which is based on CMake. Thanks to nix, I can easily check that it builds with different compilers with the help of overrideCC
. Recently, I wanted to enable LTO and use CMake’s CheckIPOSupport
to figure out whether the current compiler supports LTO. While this is fine when clang
and gcc
are directly used as buildInputs, it breaks for clang
with the overrideCC
approach:
projectWithClang = with pkgs; projectWithGcc.override {
# This override breaks LTO detection
stdenv = pkgs.overrideCC stdenv clang_9;
I set up a minimal example for reproducing the problem here: GitHub - jtraue/nix-cmake-lto-support: Minimal demo project for reproducing nix cmake build problem
The build fails when CMake tries to detect IPO support. Under the hood, a minimal project (foo) is set up, compiled and then linked with -flto
. This is where it breaks:
[3/4] Linking CXX static library libfoo.a
FAILED: libfoo.a
: && /nix/store/yvq7zkvkmycdg22l4lsr4nn20174gi74-cmake-3.16.3/bin/cmake -E
remove libfoo.a && "CMAKE_CXX_COMPILER_AR-NOTFOUND" cr libfoo.a
CMakeFiles/foo.dir/foo.cpp.o && "CMAKE_CXX_COMPILER_RANLIB-NOTFOUND"
libfoo.a && :
It seems like CMake is unable to find ar
and ranlib
. So there is probably something wrong with the overrideCC
approach. Does anyone know how to fix the problem?
