Comin: Git Push NixOS Machines
an orphan branch is just a branch with its own history (starts off with no parents).
you can empty it out and store/track whatever in it.
guix uses it to store gpg pub keys.
to avoid local eval, it can just store a single json file of nixosConfiguration store-paths.
this also keeps track of the history of deployments.
CI:
  • builds artifacts and uploads them to a cache
  • pushes a json file { "hostname": "/nix/store/...blah..." } to the orphan branch
Agent:
  • polls orphan branch and does something fancier than this gist:
#!/usr/bin/env bash
set -euo pipefail
TEMPDIR=$(mktemp -d)
trap 'rm -rf "$TEMPDIR"' EXIT
# get cached store-path from json file
git clone --depth=1 --branch="$ORPHAN" "$REPO" "$TEMPDIR"
STOREPATH=$(jq -er --arg h "$(hostname)" '.[$h]' "$TEMPDIR"/cache.json)
# TODO: add all the fancy reboot logic
CURRENT=$(readlink /run/current-system)
if [[ "$CURRENT" != "$STOREPATH" ]]; then
  # download cached store-path
  nix-store -r "$STOREPATH"
  # update profile
  nix-env -p /nix/var/nix/profiles/system --set "$STOREPATH"
  # activate
  "$STOREPATH"/bin/switch-to-configurtaion switch
fi
i can imagine something like this could fit in nicely with comin.
if not, hopefully the idea is not too off and helps a little.
I responded in the issue you created [Feature Request] Home Manager support · Issue #11 · nlewo/comin · GitHub.
Hi lewo, could you put it more prominently in the readme, that currently only gitlab tokens are supported for authentication. That is kind of a show-stopper for me (and I assume other people), and it would be really nice to see that at a glace. Or rejoice immediately when that changes and I’m re-evaluating.
Btw. any specific reason you don’t support “deploy keys” (as ghithub calls them), i.e. repository specific ssh-keys with read-only access? Or are you and I’m just misunderstanding?
I actually never consider to avoid the evaluation on the target machine … I’m however not sure this could fit well into the current comin model
I think bento does that, so at least the community has a tool. I’m really a fan of keeping it simple and not overloading with features especially in the early stages. I really like the simplicity of comin.
Quick question, the instructions in the repo specifically mention adding it to configuration.nix - am I correct in my interpretation, that means it doesn’t support flakes?
No, it actually only supports flakes! I think the readme should be more explicit about that btw.
In the readme, the only mention to the authentication is a link to the documentation and this documentation starts by “Currently, only the GitLab personnal access token is supported”. I would actually prefer to avoid talking about authentication directly in the readme itself to keep it short.
The only reason is that I didn’t take time to try with GitHub (all my NixOS configuration are on GitLab instances).
But, it seems the current implementation is almost working for GitHub: we should just add another option allowing the user to provide a user name (which is not required by the GitLab auth).
Note there is an issue on this topic: Support private GitHub repositories · Issue #6 · nlewo/comin · GitHub (i should fix it in the next following weeks).
Correct and Cachix Deploy also avoids the evaluation on the target.
I agree with you. Also, I have a lot of other features to add before considering this use case…
Thank you for you message and I ping you when the GitHub auth is implemented :wink:
Thank you for sharing your ideas!
I don’t plan to think/work on this topic soon but there is an issue related to this use case.
Actually, GitHub personal access token (PAT) works like GitLab PAT… so, the autentication with GitHub was already working!
So, i then added a section in the comin documentation to authenticate on GitHub private repo.
comin v0.2.0 has been released.
  • Expose some Prometheus metrics
comin v0.5.0 is out :tada:
Release Profiles · nlewo/comin · GitHub
I really like the model where the various nodes autonomously poll a few repositories. This way those central machines hosting the repositories do not need to have access to any of the nodes and make them a less appealing target for attackers.
I see no mention of it in the repo but would it be able to authenticate to a Forgejo instance? I think the auth mechanism is similar to GitLab. I’ll try it out.
Also it happened to me already to lose SSH access to the box because of a bad config and this model would helps in some of those cases.
Thanks for writing this tool, I’ll definitely try it out soon.
Also I recommend everyone to listen to your talk about comin, it’s great! https://youtu.be/UaIKO_njUWA?si=xP2alYuwMVtg2iSl
v0.7.1 is out :rocket:
Thanks to @tcurdt, there is now the option services.comin.postDeploymentCommand allowing comin to run a custom script after each deployment.
See comin/docs/generated-module-options.md at 4df4e3cdf3d99df282c23c03c87654687389b428 · nlewo/comin · GitHub for details.
v0.8.0 is out :tada:
comin is now able to deploy configuration on nix-darwin machines. See comin/docs/howtos.md at main · nlewo/comin · GitHub.
Thanks @multivac61 for #89 :+1:
v0.10.0 is out :tada:
New features
Note that several other features have also been introduced but I don’t announce them yet since they are not well polished for now… Stay tuned for next release announcements!
Release contributors
Thanks to this release contributors:
We now have a Matrix room to discuss about comin features and issues!
Feel free to join https://matrix.to/#/#nixos-comin:matrix.org.
[v0.12.0]( Release v0.12.0 · nlewo/comin · GitHub ) is out :tada:
The main change is the support of Git submodules, contributed by Keyruu (Lucas) · GitHub in feat: reformat everything and add flake check by Keyruu · Pull Request #140 · nlewo/comin · GitHub.
[v0.13.0] - 2026-05-07
Added
  • comin watch command for monitoring repositories
  • Fetcher support to watch functionality
  • Support for proxies (#150)
Changed
  • Use a bare local repository for git operations (#154)
  • CLI: improved messages (#145)
Fixed
  • Desktop: fix typo (#145)
v0.14.0 is out :tada:
This mainly brings the support for SSH authentication and SSH commit signatures.
Added
  • SSH commit signature verification: Support for verifying Git commits signed with SSH keys (#171
  • SSH key authentication: Support for SSH key authentication for Git operations (#168)
  • Customizable build and evaluation timeouts (#174)
  • Support for switch inhibitors (#156)
Changed
  • deployment submit-latest command replacing switch-latest (#152)
  • Use bare local repository for git operations (#154)
Contributors
