Comprehensive reference for flake input syntax?
I ended up here
https://nix.dev/manual/nix/2.28/command-ref/new-cli/nix3-flake.html#flake-inputs
Looking for a reference for flake inputs. Unfortunately its only an overview with a smattering of examples. I’m looking for a reference.
For instance, it has this example:
inputs.import-cargo = {
  type = "github";
  owner = "edolstra";
  repo = "import-cargo";
And that’s great. But what about gitlab, or other repos? What about more obscure things like
?submodules=1 or rev=?
How about a full reference? What are ALL the possible options for an input, and what are ALL the possible values for each of those?
https://nix.dev/manual/nix/2.32/command-ref/new-cli/nix3-flake.html#types
AIUI these are just args passed to fetchTree, so those docs would sort-of cover it. Params seem to be implicitly converted to attrs.
https://nix.dev/manual/nix/2.32/language/builtins.html#source-types
But the actual URL-like syntax is not clearly documented.
This doesn’t perfectly cover the non-url schema either, FWIW, some attributes are undocumented, particularly for those bonus fetcher args. I’ve butted my head against this before, too.
I don’t think a comprehensive reference currently exists. But it’s fine, flakes are still experimental, right?
