I want to make my laptop hibernate when battery is critically low but can’t find the config for that.
The stockholm repository has something similar to what you are looking for, it is a module which provides the means to trigger actions for different power levels (e.g. between 25% and 15% or below 15%): Sign in · GitLab
This is how i use the module for my laptop:
If you do not want the full-fledge version then you can probably copy-paste the relevant parts into your config
Funny, just an hour ago I added code for that to my config.
But if your battery sends discharging events, you probably want a udev rule (as described in the arch wiki).
Great to learn about these. Thank you all.
To other people just finding this now on Google, you can edit upower settings in Nixos like this
services.upower.criticalPowerAction = "Hibernate";
