On my home server, I’m trying to set up a container to use OpenVPN for external networking. I also need to access some services running in this container from internal network, so I want to forward those ports to the host.
Network setup I’m trying to achieve (slightly simplified, actually I want to forward multiple ports):
desktop
ip 192.168.1.10
nix-host:
eno1 ip 192.168.1.20
ve-container ip 192.168.10.1
port forward port 8000 to 192.168.10.2:8000
container:
eth0 ip 192.168.10.2
tun0 ip xxx.xxx.xxx.xxx (whatever VPN ip)
The config I’m currently using
networking.nat = {
externalInterface = "eno1";
internalInterfaces = ["ve-container"];
networking.firewall.allowedTCPPorts = [ 8000 ];
containers.container = {
ephemeral = true;
autoStart = true;
enableTun = true;
privateNetwork = true;
hostAddress = "192.168.10.1";
localAddress = "192.168.10.2";
forwardPorts = [
{ protocol = "tcp"; hostPort = 8000; containerPort = 8000; }
config = {
networking.defaultGateway.address = "192.168.10.1";
networking.nameservers = [ "8.8.8.8" ];
networking.firewall.interfaces = {
"eth0".allowedTCPPorts = [ 8000 ];
networking.useDHCP = false;
# openvpn config
services.openvpn.servers = {
myVPN = {
What works
- VPN, verified by doing
curl ifconfig.me
in the container. - Connections from nix-host to container with port 8000, verified with
nc
(and other software)
What doesn’t work
- Connections from desktop to nix-host:8000
Weird stuff
- If I disable the VPN, port forwarding works as expected.
What I’ve tried
- Putting the port forward in
networking.nat.forwardPorts
instead ofcontainers.container.forwardPorts
. This also only works when VPN is not enabled. - Creating a bridge interface to give the container its own IP in host’s network. I wasn’t able to make this work even without VPN yet though.
Any ideas for what to try next? Is there some detail or quirk I’m missing?
