Could not get flakes + home manager to work in a decent way
So, I started modularizing my nix config and using vimjoyer videos + online tutorials i managed to get started with creating a basic structure from a flake that will handle both my desktop workstation and my ideapad laptop using a global config and home manager for a user.
below it’s what i did so far.
    description = "my nixos config for both my laptop and my workstation";
        nixpkgs.url = "nixpkgs/nixos-24.11";
        home-manager = {
            url = "github:nix-community/home-manager/release-24.11";
    outputs = { self, nixpkgs, home-manager, ... }:
            lib = nixpkgs.lib;
            system = "x86_64-linux";
            nixosConfigurations = {
                ideapad = nixpkgs.lib.nixosSystem {
                    inherit system;
                    modules = [
                        "./ideapad/modules/global/bootloader.nix"
                workstation = nixpkgs.lib.nixosSystem {
                    inherit system;
                    modules = [];
            homeConfigurations = {
                ideapad = home-manager.lib.homeManagerConfiguration {
                    inherit pkgs;
                    modules = [./ideapad/home.nix];
                workstation = home-manager.lib.homeManagerConfiguration {
                    inherit pkgs;
                    modules = [];
Problem is that when i use nix flake update and then nix flake show
i get unknown homeConfiguration and I don’t believe it is intended.
What will be the painless way to
continue modularizing my monolithic configuration.nix into modules related on topis [ as of now i just modularized specific grub options for my laptop]
decide what programs i have to install via global pkgs and what via home manager (e.g. alacritty discord nodejs)
i really can’t get how overlays and external flakes works, even with guides, can you give me a direct example of advantages and all?
thank you so much, I’m really sorry if i suounded dumb
That’s expected, currently.
