Couldn't nixos-rebuild: error: cython-0.29.37.1 not supported for interpreter python3.13
I updated recently, and now, running nixos-rebuild results in this error:
error:
         at /nix/store/igmrb3hj6wr27ll3nlgjfaawf5jsjvji-source/lib/attrsets.nix:1534:13:
         1533|           if length values == 1 || pred here (elemAt values 1) (head values) then
         1534|             head values
         1535|           else
         at /nix/store/igmrb3hj6wr27ll3nlgjfaawf5jsjvji-source/lib/modules.nix:1086:7:
         1085|     // {
         1086|       value = addErrorContext "while evaluating the option `${showOption loc}':" value;
         1087|       inherit (res.defsFinal') highestPrio;
       … while evaluating the option `system.build.toplevel':
       … while evaluating definitions from `/nix/store/igmrb3hj6wr27ll3nlgjfaawf5jsjvji-source/nixos/modules/system/activation/top-level.nix':
       … while evaluating the option `warnings':
       … while evaluating definitions from `/nix/store/igmrb3hj6wr27ll3nlgjfaawf5jsjvji-source/nixos/modules/system/boot/systemd.nix':
       … while evaluating the option `systemd.services.home-manager-n3rdium.serviceConfig':
       … while evaluating definitions from `/nix/store/70rg0z7glhanwg8rwg24cl5x75kdd322-source/nixos':
       … while evaluating the option `home-manager.users.n3rdium.home.file."/home/n3rdium/.config/fontconfig/conf.d/10-hm-fonts.conf".source':
       … while evaluating definitions from `/nix/store/70rg0z7glhanwg8rwg24cl5x75kdd322-source/modules/files.nix':
       … while evaluating the option `home-manager.users.n3rdium.home.file."/home/n3rdium/.config/fontconfig/conf.d/10-hm-fonts.conf".text':
       … while evaluating definitions from `/nix/store/70rg0z7glhanwg8rwg24cl5x75kdd322-source/modules/misc/xdg.nix':
       … while evaluating the option `home-manager.users.n3rdium.xdg.configFile."fontconfig/conf.d/10-hm-fonts.conf".text':
       … while evaluating definitions from `/nix/store/70rg0z7glhanwg8rwg24cl5x75kdd322-source/modules/misc/fontconfig.nix':
Command '['nix', '--extra-experimental-features', 'nix-command flakes', 'build', '--print-out-paths', 'git+file:///home/n3rdium/.dotfiles#nixosConfigurations."n3rdium".config.system.build.toplevel', '--no-link']' returned non-zero exit status 1.
I think this problem comes from nix migrating to python3.13.
I spent some time looking at nixpkgs’s .nix files looking if any of the apps I have installed had Cython as dependancy, but found nothing. (Also that might not be the way to look for dependancies)
I solved this by restoring my flake.lock file to a previous version.
Inside nix flake repo:
Find in which commit lock was updated
git log -- flake.lock
copy the latest hash that doesn’t ends with (HEAD -> Main) (Main or your branch’s name)
If you want to be sure that the lock changed in that commit:
git diff commitHash flake.lock
Restore lock
git checkout commitHash flake.lock
I know this might not be the best solution, but I hope it helps until someone that really knows can solve this problem.
(Or maybe Cython fix itself to support python 3.13)
Fixed this temporarily by removing the lmms package.
It depends on the carla library which depends on liblo, which is the root cause of this error. I guess I have to wait for it to be fixed before I can use lmms again?
