Creating tarball compatible with package attribute sets (channel) and overlay
What is the convention for creating a tarball that works both as a package set and an overlay. Is it to create two tarballs, one for the package set and one for the overlay or is it some way to combine them. Both are using the default.nix and when provided as a tarball URL, you can’t specify the entry point.
I currently have something like this:
{ overlaySupport ? false
, pkgs ? import <nixpkgs> {}
  overlay = import ./pkgs/all-packages.nix;
  allPackages = overlay allPackages pkgs;
in if overlaySupport
   then overlay
   else allPackages
Which would allow something like this:
  customOverlay = import (builtins.fetchTarball {
    url = "file:///custompkgs.tar.gz";
    sha256 = "...";
  }) { overlaySupport = true; };
in import <nixpkgs> {
  overlays = [ customOverlay ];
And I also considered to do something like this:
in allPackages // { inherit overlay; }
Which would allow:
  customOverlay = (import (builtins.fetchTarball {
    sha256 = "...";
  }) { }).overlay
But would these two even be considered overlay compatible. Could they work via nixpkgs-overlays in NIX_PATH? I guess not.
Requirements:
I want to be able to use the tarball as an overlay, via e.g. builtins.fetchTarball.
I want to be able to install individual packages via the tarball, such as:
nix-env -f file:///custompkgs.tar.gz -iA custompackage
I want to be able to add the package set as a channel:
nix-channel --add file:///custompkgs.tar.gz custompkgs
Preferably when using as an overlay it should just be:
    sha256 = "...";
Is there a way to satisfy both with a single default.nix? Or should I package the overlay and package set separately.
