Hello!
I am trying to cross-compile a Go program to aarch64-linux
(GOARCH=arm64
) from a x86_64-linux
host (without emulation). Compiling for x86_64-linux
works:
$ nix-build default.nix
/nix/store/zs9981qyq1xzfp514xakap5xcmq99icq-parca-agent-26f5194fd9477ec8ccb0e35f9677275c09211d7e
But for aarch64-linux
, I get 'gnu/stubs-32.h' file not found
$ nix-build --arg crossSystem '"aarch64-linux"'
Building subPackage ./cmd/parca-agent
# runtime/cgo
In file included from _cgo_export.c:3:
In file included from /nix/store/mmmjp0xcmr0dm307jv1l34hvi95z6d8s-glibc-2.35-224-dev/include/stdlib.h:26:
In file included from /nix/store/mmmjp0xcmr0dm307jv1l34hvi95z6d8s-glibc-2.35-224-dev/include/bits/libc-header-start.h:33:
In file included from /nix/store/mmmjp0xcmr0dm307jv1l34hvi95z6d8s-glibc-2.35-224-dev/include/features.h:514:
/nix/store/mmmjp0xcmr0dm307jv1l34hvi95z6d8s-glibc-2.35-224-dev/include/gnu/stubs.h:7:11: fatal error: 'gnu/stubs-32.h' file not found
I have seen this error in a handful of GitHub issues and posts here, but none of the answers help (e.g. using glibc_multi
throws error: i686 Linux package set can only be used with the x86 family.
Here is what I use (simplified and self-contained):
{ pkgs ? import
(builtins.fetchTarball {
# nixos-unstable as of Tue, 6 Dec 2022 08:21:00 +0530 (latest revision with libbpf 1.0.1)
name = "nixos-unstable-2022-12-06";
url = "https://github.com/nixos/nixpkgs/archive/b10a520017ac319c1e57b07742efd2bcc918d160.tar.gz";
sha256 = "0jdf78gjrhpj501i0qd79sy7nd2sfwvd5y67ixjggmbj93a6i7kx";
{ crossSystem = crossSystem; }
, crossSystem ? null
, runTests ? false
inherit (pkgs) pkgsBuildBuild pkgsHostTarget;
# bpf = pkgsBuildBuild.callPackage ./bpf { pkgs = pkgs; };
# Dummy BPF program for simplification
bpf = pkgsBuildBuild.writeTextDir "cpu.bpf.o" "";
(pkgsBuildBuild.buildGo119Module.override {
stdenv = pkgsBuildBuild.llvmPackages_14.stdenv;
}) rec {
pname = "parca-agent";
version = "26f5194fd9477ec8ccb0e35f9677275c09211d7e";
src = pkgsBuildBuild.fetchFromGitHub {
owner = "parca-dev";
repo = pname;
rev = version;
sha256 = "sha256-e+VO/BmXSygfyjIlnkFgPW8jsQrcItX0icYI1xOY7pc=";
vendorSha256 = "sha256-knGgdAY9YNBfV0xkGc0GZq7hyHeR1C6yyGEpZIBzKDo=";
nativeBuildInputs = with pkgsBuildBuild; [ nukeReferences ];
buildInputs = with pkgsHostTarget; [
elfutils.dev
glibc.static
libbpf
zlib.static
CGO_CFLAGS = "--target=${pkgsHostTarget.hostPlatform.config}";
CGO_LDFLAGS = "--target=${pkgsHostTarget.hostPlatform.config} -fuse-ld=ld -lbpf";
GOOS = pkgsHostTarget.go.GOOS;
GOARCH = pkgsHostTarget.go.GOARCH;
ldflags = [ "-extldflags=-static" ];
tags = [ "osusergo" "netgo" ];
subPackages = "cmd/parca-agent";
# Tests for these packages have additional requirements
excludedPackages = "internal/pprof pkg/profiler e2e";
preBuild = ''
cp -f ${bpf}/cpu.bpf.o ./pkg/profiler/cpu/cpu-profiler.bpf.o
# Nuke any references to other Nix store paths
# https://github.com/NixOS/nixpkgs/blob/ccb52a00240f7bc4db651ac6521d42316361df56/pkgs/build-support/nuke-references/default.nix#L1-L4
postBuild = ''
nuke-refs "$GOPATH/bin/parca-agent"
# Not necessary and/or desired (e.g. strip, patchelf...)
# https://nixos.org/manual/nixpkgs/stable/#ssec-fixup-phase
dontFixup = true;
doCheck = runTests;
# Test all packages
preCheck = ''
unset subPackages
I suspect I need to override the libc
in stdenv
to use the one for the host platform, but I cannot figure out how. (I also have a requirement to compile with clang
since it is what we have been using so far)
This is my first attempt at cross-compilation with Nix, so any tips on the overall approach would also be welcome
I tried to configure the stdenv
compiler to use the libraries of the host platform with overrideCC
stdenv = pkgsBuildBuild.overrideCC pkgsBuildBuild.llvmPackages_14.stdenv (
pkgsBuildBuild.clang.override {
libc = pkgsHostTarget.glibc;
bintools = pkgs.pkgsBuildHost.clang.bintools.override {
gccForLibs = pkgs.pkgsBuildHost.gcc.cc;
But I think my compiler config is still wrong
$ nix-build default.nix --arg crossSystem '"aarch64-linux"'
# runtime/cgo
gcc_amd64.S:25:8: error: unknown token in expression
pushq %rbx
gcc_amd64.S:25:8: error: invalid operand
pushq %rbx
gcc_amd64.S:26:8: error: unknown token in expression
pushq %rbp
gcc_amd64.S:26:8: error: invalid operand
pushq %rbp
gcc_amd64.S:27:8: error: unknown token in expression
pushq %r12
gcc_amd64.S:27:8: error: invalid operand
pushq %r12
gcc_amd64.S:28:8: error: unknown token in expression
pushq %r13
gcc_amd64.S:28:8: error: invalid operand
pushq %r13
gcc_amd64.S:29:8: error: unknown token in expression
pushq %r14
gcc_amd64.S:29:8: error: invalid operand
pushq %r14
gcc_amd64.S:30:8: error: unknown token in expression
pushq %r15
gcc_amd64.S:30:8: error: invalid operand
pushq %r15
gcc_amd64.S:37:7: error: unknown token in expression
movq %rdi, %rbx
gcc_amd64.S:37:7: error: invalid operand
movq %rdi, %rbx
gcc_amd64.S:38:7: error: unknown token in expression
movq %rdx, %rdi
gcc_amd64.S:38:7: error: invalid operand
movq %rdx, %rdi
gcc_amd64.S:39:7: error: unknown token in expression
call *%rsi
gcc_amd64.S:39:7: error: invalid operand
call *%rsi
gcc_amd64.S:40:7: error: unknown token in expression
call *%rbx
gcc_amd64.S:40:7: error: invalid operand
call *%rbx
gcc_amd64.S:43:7: error: unknown token in expression
popq %r15
gcc_amd64.S:43:7: error: invalid operand
popq %r15
gcc_amd64.S:44:7: error: unknown token in expression
popq %r14
gcc_amd64.S:44:7: error: invalid operand
popq %r14
gcc_amd64.S:45:7: error: unknown token in expression
popq %r13
gcc_amd64.S:45:7: error: invalid operand
popq %r13
gcc_amd64.S:46:7: error: unknown token in expression
popq %r12
gcc_amd64.S:46:7: error: invalid operand
popq %r12
gcc_amd64.S:47:7: error: unknown token in expression
popq %rbp
gcc_amd64.S:47:7: error: invalid operand
popq %rbp
gcc_amd64.S:48:7: error: unknown token in expression
popq %rbx
gcc_amd64.S:48:7: error: invalid operand
popq %rbx
I must be missing something about cross-compilation. Something I do not even know I do not know.
Figured it out!
The answer:
pkgs.pkgsHostTarget.buildGo119Module.override {
stdenv = pkgsHostTarget.llvmPackages_14.stdenv;
Here is the fixed derivation:
{ pkgs ? import
, runTests ? false
inherit (pkgs) pkgsBuildHost pkgsHostTarget;
# bpf = pkgsBuildHost.callPackage ./bpf { pkgs = pkgs; };
bpf = pkgsHostTarget.writeTextDir "cpu.bpf.o" "";
(pkgs.pkgsHostTarget.buildGo119Module.override {
}) rec {
src = pkgsBuildHost.fetchFromGitHub {
repo = pname;
rev = version;
nativeBuildInputs = with pkgsBuildHost; [
nukeReferences
elfutils.dev
glibc.static
libbpf
zlib.static
CGO_LDFLAGS = "-lbpf";
preBuild = ''
postBuild = ''
dontFixup = true;
doCheck = runTests;
# Test all packages
preCheck = ''
unset subPackages
I am still a bit confused about the pkgs<host><target>
attributes, but it works, it just need some more testing to make sure everything is good.
Documentation for reference: Nixpkgs 22.11 manual
Cool, this might come in handy for later reference…
As a side note; I’ve seen cases where CGO
is on by default even when it would not have been necessary; this then can make sensitivity to arch-related issues much worse. So I settled for always explicitly setting CGO=0
unless it is explicitly necessary (usually due to a dependency like e.g. sqlite
