Dconf2nix help. Incorrect translation
Hi there.
I changed a few settings in Blackbox terminal which stores its settings in dconf.
Now when I dump the appropriate path, I see:
λ dconf dump /com/raggesilver/BlackBox/
<snip>
terminal-padding=(uint32 20, uint32 20, uint32 20, uint32 20)
</snip>
Now when I run this through dconf2nix, I see the padding is converted to:
terminal-padding = mkTuple [ mkUint32 20 mkUint32 20 ];
Now I have narrowed down that this specific line caused a 702 line trace. :rofl:
for those who are dconf experts, is this the right output? Is there another format I can use to set this up? I am wondering if the issue is that there are only 2 mkUint32 20 vs the 4 uint32 20, in the dconf dump.
Thoughts?
Sounds like you discovered not one but two different bugs in dconf2nix:
  • In Nix, list items need to be parenthesized if they contain space, otherwise the function and the argument will become a separate list items.
  • The number of items in the tuple should match, otherwise size 2 tuple will be produced where the app expects size 4
The following should be the correct translation:
terminal-padding = mkTuple [ (mkUint32 20) (mkUint32 20) (mkUint32 20) (mkUint32 20) ];
OMG - THANK YOU.
That was driving me insane!
Please also open issues in the dconf2nix repo so that the bugs can be properly fixed.
