Newbie here.
I’m trying to set up a flake.nix
file for a projects. I see a couple of different conflicting things online on how to best tackle the situation. The two normal-est I see right now are to either use node2nix
or leverage your package-lock.json
and just install via npm
as a part of mkDerivation
. Neither of these solution seem to be working for me and I don’t really have my bearings on how to read the error outputs or effectively use the right keywords on a web search. I’m also curious if making node_modules
a separate “app” in the Flake world is what makes the most sense.
In my case, I’m trying to use parcel@2.0.0-beta.2
(v1.x in nixpkgs is missing features I need) to compile and bundle various sources together for distribution for a static site.
When I tried node2nix
I ran into issues with node-gyp-build
for native modules in Parcel. Following the documentation and adding pkgs.nodePackages.node-gyp-build
to the buildInputs
did not help and the error NPM wants to give me is in /build/.npm/_logs/xxx
which I couldn’t figure out where it was to read since the build failed to produce the derivation. I also don’t see in this manner what node2nix
really gives me as it seems to be reimplementing what NPM does but is slower.
Trying to run NPM as a part of any of the build steps just ran into sandboxing issues I wasn’t understanding and again the build failed so the NPM logs are then gone(?). Do I want to have node_modules
and the relevant binaries as a part of my Nix store or is it not needed or valuable?
Previously I was just using Nix+Flakes to make dev shells and it’s been really nice and Flakes has made it fast and easy to upgrade. I’ve just been using NPM (or Yarn) and doing my work as I was previously using asdf
, but now I’d like to actually use nix build
but it hasn’t been to straightforward to me on how use Node packages and their binaries for this step. I didn’t have much luck searching other open source projects to understand either.
Any higher-level reading material on the subject or existing, Node-using projects to look at would be greatly appreciated.
