This is enabled bij default when using services.xserver.desktopManager.xfce.enable = true;
Not that I know and I don’t have the full Gnome desktop installed only parts of it.
My WM is Qtile.
Edit I can try if it works with Thunar when I’m back home.
Worked with Thunar as well.
I found services.udisks2.enable in my config.
Maybe that is what allows unlocking the drives?
I thougt so, but it is already enabled by default.
Ah shit sorry for the duplicate ![]()
Nevermind, thanks for helping anyway
Perhaps you can share your configuration.nix? If I can create a similar working setup, then I can look for possible differences with my desired setup.
Sure but it won’t be that easy to look through.
My config lives here: GitHub - Nebucatnetzer/nixos
Maybe the relevant part lives here: nixos/modules/profiles/desktop/default.nix at master · Nebucatnetzer/nixos · GitHub
Or here: nixos/modules/services/tiling-wm-base/default.nix at master · Nebucatnetzer/nixos · GitHub
Or somewhere else🤪.
Well, I’ve finally figured it out ![]()
Yesterday I started looking at the configuration of @Nebucatnetzer and applied it to a VM NixOS with a similar setup as my laptop. Nothing worked. Then I tried to do the same in my Kali Linux VM, and supprisingly it worked by only adding the polkit rules.
So whats the difference? Well, evenrything between the '' <polkit rule> '' is added to the polkit configuration, including the comment # <comment>. However, when searching for polkit rules, a comment has to be formatted lik this: /* <comment */. After changing that, I did not have to enter my account password anymore when unlocking the second disk, only the passphrase.
So, instead of doing this:
security.polkit.extraConfig = ''
# Allow udisks2 to mount devices without authentication
# for users in the "wheel" group.
...SNIP...
You have to do this:
/* Allow udisks2 to mount devices without authentication for users in the "wheel" group. */
...SNIP...
Or you can do this:
...SNIP...
Thanks all for helping me out!
