I have been trying to use nix inside a container and nix-shell command seems to work correctly but anything other than that (nix profile, nix-env, nix develop etc) fails with this error
error:
… while waiting for the build environment for '/nix/store/7r2gqdwc4m6yykzghiz9j3d0jdwg5cjv-builder.pl.drv' to initialize (succeeded, previous messages: )
error: reading a line: Input/output error
I tried to create my dockerfile using the official nix docker image as base and ran into the same issue
This issue occurs regardless of whether root user or a normal user is trying to execute these commands
The flake which I am using to create the environment in the container
nixpkgs.url = "/var/cache/nixpkgs/NixOS-nixpkgs-b27ba4e";
flake-parts.url = "/var/cache/flake-parts-main";
process-compose-flake.url = "/var/cache/process-compose-flake-main";
services-flake.url = "/var/cache/services-flake-main";
outputs = inputs: inputs.flake-parts.lib.mkFlake { inherit inputs; } {
systems = [ "x86_64-linux" "aarch64-darwin" "x86_64-darwin" "aarch64-linux" ];
imports = [
inputs.process-compose-flake.flakeModule
perSystem = { self', pkgs, lib, system, ... }: {
_module.args.pkgs = import inputs.nixpkgs {
inherit system;
config.allowUnfree = true;
packages.default = pkgs.buildEnv {
name = "Odin-Sandbox-Env";
paths = with pkgs; [
vim
gnupatch
buildInputs = with pkgs; [
vim
gnupatch
process-compose."odin" = pc: {
imports = [
inputs.services-flake.processComposeModules.default
services = {
flake = {
This works on my system correctly but fails inside the container and if I try to install the profile when I am building the dockerfile it works but when I exec into the container and try to install the profile it fails
