Equivalent of `--override-input` for `builtins.getFlake`
On the command-line, I can build a flake with my current revision of nixpkgs with --override-input:
nix build --override-input nixpkgs /home/aengelen/nixpkgs
Is it possible to do the same inside a derivation that uses builtins.getFlake? Instead of:
((builtins.getFlake "git+https://codeberg.org/raboof/vola
re?rev=a84e9c68aba236dc90a03a2117dcb5a79cb955a2").packages.x86
_64-linux.default)
… I could perhaps put some kind of override or repackaging before invoking .packages?
Is the call to builtins.getFlake your code?
If instead it was listed as inputs.vola.url = ... you could override it in the same way you override nixpkgs.
Yes, I’m using it to include a flake-packaged application in my (‘classic’) configuration.nix, and elsewhere as part of an mkShell that is invoked with nix-shell.
Yeah basically that’s your only option right now.
Basically, you have to fetch the original flake using fetchgit and apply a patch to that inserts inputs.nixpkgs.follows = "/home/aengelen/nixpkgs"; in one derivation, and then use the output path of that derivation as the input to getFlake. This will work because getFlake happily accepts a local path to a flake.
Is that enough info for you to get started?
What solution have you settled on? Fetching the flake and then patching the source?
For now I’m just using a local checkout of the flake where I have flake.lock in sync with the current nixpkgs on that system. Obviously less than ideal :slight_smile: .
