Error 'illegal path references in fixed-output derivation' when using maven
Hi!
I’ve been trying to create a derivation for jmc. So the first thing I did was using BuildMavenPackage, but then realized I need to write a toolchains.xml file so I created a new derivation to replace build-maven-package.nix, this is the code I ended up with:
# nix-build --keep-failed maven.nix
  pkgs = import <nixpkgs> { };
  lib = pkgs.lib;
  buildOffline = false;
  stdenv = pkgs.stdenv;
  jdk = pkgs.jdk;
  manualMvnArtifacts = [ ];
  manualMvnSources = [ ];
  mvnHash = "";
  mvnDepsParameters = "";
  mvnSkipTests = "-DskipTests";
  mvnParameters = "";
  maven = pkgs.maven;
  jdk17 = pkgs.jdk17;
  pname = "jmc";
  version = "1.2.1";
  src = pkgs.fetchFromGitHub {
    owner = "openjdk";
    repo = pname;
    rev = "cf85dbcb3872bd31c7d8145833eacda148455b3e";
    hash = "sha256-d95b0sTLn6DHkh2SFAXTmiLr1INEF/UDxsIWF5E5yJY=";
stdenv.mkDerivation ({
  name = "${pname}-${version}-maven-deps";
  inherit src;
  nativeBuildInputs = [
    maven
  JAVA_HOME = jdk;
  JAVA_17HOME = jdk17;
  NIX_DEBUG = 7;
  buildPhase = ''
          echo "Hello fetchedMavenDeps buildPhase"
          runHook preBuild
          mkdir -p $out/.m2
          cat >$out/.m2/toolchains.xml <<EOL
    <?xml version="1.0" encoding="UTF-8"?>
    <toolchains>
      <toolchain>
        <type>jdk</type>
        <provides>
          <id>JavaSE-17</id>
          <version>17</version>
          <vendor>openjdk</vendor> <!-- or oracle depending on your setup -->
        </provides>
        <configuration>
          <jdkHome>${jdk17.outPath}/lib/openjdk</jdkHome>
        </configuration>
      </toolchain>
      <toolchain>
        <type>jdk</type>
        <provides>
          <id>JavaSE-21</id>
          <version>21</version>
        </provides>
        <configuration>
          <jdkHome>${jdk.outPath}/lib/openjdk</jdkHome>
        </configuration>
      </toolchain>
    </toolchains>
    EOL
          echo COCONUT
          cat $out/.m2/toolchains.xml
  '' + lib.optionalString buildOffline ''
    mvn de.qaware.maven:go-offline-maven-plugin:1.2.8:resolve-dependencies -Dmaven.repo.local=$out/.m2 ${mvnDepsParameters}
    for artifactId in ${builtins.toString manualMvnArtifacts}
    do
      echo "downloading manual $artifactId"
      mvn dependency:get -Dartifact="$artifactId" -Dmaven.repo.local=$out/.m2
    done
    for artifactId in ${builtins.toString manualMvnSources}
    do
      group=$(echo $artifactId | cut -d':' -f1)
      artifact=$(echo $artifactId | cut -d':' -f2)
      echo "downloading manual sources $artifactId"
      mvn dependency:sources -DincludeGroupIds="$group" -DincludeArtifactIds="$artifact" -Dmaven.repo.local=$out/.m2
    done
  '' + lib.optionalString (!buildOffline) ''
    mvn p2:site --file releng/third-party/pom.xml -Dmaven.repo.local=$out/.m2
    mvn jetty:run --file releng/third-party/pom.xml -Dmaven.repo.local=$out/.m2 &
    echo "WTFFF@@@"
    mvn toolchains:display-discovered-jdk-toolchains -Dmaven.repo.local=$out/.m2
    mvn toolchains:generate-jdk-toolchains-xml  -Dmaven.repo.local=$out/.m2
    echo "MVN CLEAN INSTALL"
    mvn --toolchains $out/.m2/toolchains.xml clean install --file core/pom.xml -Dmaven.repo.local=$out/.m2 -Dmaven.test.skip=true
    echo "MVN DEPENDENCY"
    mvn --toolchains $out/.m2/toolchains.xml dependency:resolve -Dmaven.repo.local=$out/.m2
    echo "MVN PACKAGE"
    mvn --toolchains $out/.m2/toolchains.xml package -Dmaven.repo.local=$out/.m2 ${mvnSkipTests} ${mvnParameters}
    echo "Goodbye fetchedMavenDeps buildPhase"
    runHook postBuild
  # keep only *.{pom,jar,sha1,nbm} and delete all ephemeral files with lastModified timestamps inside
  installPhase = ''
    echo "Hello fetchedMavenDeps installPhase"
    runHook preInstall
    find $out -type f \( \
      -name \*.lastUpdated \
      -o -name resolver-status.properties \
      -o -name _remote.repositories \) \
      -delete
    echo "Goodbye fetchedMavenDeps installPhase"
    runHook postInstall
  # don't do any fixup
  dontFixup = true;
  outputHashAlgo = if mvnHash != "" then null else "sha256";
  outputHashMode = "recursive";
  outputHash = mvnHash;
The build does print Goodbye fetchedMavenDeps installPhase but at the end I get this message
error: illegal path references in fixed-output derivation '/nix/store/1zv31z9kh7ini8r6iz0lirhpfqj99r8q-jmc-1.2.1-maven-deps.drv'
I searched in nix’s source code for that ‘illegal’ line and rebuild nix to print what the contents of newInfo0.references are. Which turn out to be
59flqcj6x3dxiwjavxkwrycamg0482yb-openjdk-21.0.3+9
xy53lk4001h814d7dwh8f52wcqxrn7rp-openjdk-17.0.11+9
Now I’m pretty much stuck, not knowing what to do with that information.
