Error when using sops-nix.nixosModule inside homeConfigurations
Hello community, this is my first post here and I’d really appreciate your help.
My goal is to use sops-nix secrets with home-manager’s programs.ssh so I’m trying to use inputs.sops-nix.nixosModules.sops inside of homeConfigurations but I’m getting the following error when building with home-manager switch --flake .
error: cannot coerce null to a string
       at /nix/store/jamgsam32gs76c2h5wz97sxfw0kcsyqz-source/modules/sops/default.nix:344:23:
          343|         generate-age-key = mkIf (cfg.age.generateKey) (stringAfter [] ''
          344|           if [[ ! -f '${cfg.age.keyFile}' ]]; then
          345|             echo generating machine-specific age key...
(use '--show-trace' to show detailed location information
I guess that it’s not getting config but I’m clueless as to why, cause I can use inputs.sops-nix.nixosModules.sops inside of nixosConfigurations just fine. Here are my relevant files.
# flake.nix
    nixpkgs.url = "nixpkgs/nixos-22.05";
    nvim.url = "/home/nixos/system/home/nvim";
    nixos-hardware.url = "github:NixOS/nixos-hardware/master";
    home-manager = {
      url = "github:nix-community/home-manager/release-22.05";
    sops-nix = {
      url = "github:mic92/sops-nix";
  outputs = inputs@{ self, nixos-hardware, nixpkgs, nvim, home-manager, sops-nix, ... }: let
    hostnames = builtins.attrNames (builtins.readDir ./hosts);
    system = "x86_64-linux";
    nixosConfigurations = builtins.listToAttrs (builtins.map (host: {
      name = host;
      value = inputs.nixpkgs.lib.nixosSystem {
        inherit system;
        modules = [
          { _module.args = inputs; }
          ./hosts/${host}/configuration.nix
    }) hostnames);
    homeConfigurations.nixos = home-manager.lib.homeManagerConfiguration {
      inherit system;
      configuration = ./home/home.nix;
      homeDirectory = "/home/nixos";
      username = "nixos";
      stateVersion = "22.05";
      extraSpecialArgs = { inherit inputs; };
# home/home.nix
{ inputs, lib, config, pkgs, ... }:
  imports = [
I’ve been looking at other peoples configs and reading at the NixOS manual but I can’t find the solution. Been using NixOS for about 2 months on my own and this is my first dead end, so I thought it would be a good opportunity to get in touch with the community.
I would really appreciate any help, cheers.
Sops-nix doesn’t have home-manager support as far as I remember.
And importing a “nixosModule” into a home manager configuration is usually not expected to work, due to the different options they provide.
That makes sense. Will configure ssh from configuration.nix then. Thanks for your response.
