Flake issue: error does not provide attributes
Hi all, road blocked for me when installing nix-darwin with home-manager on my system.
nix-info -m
 - system: `"x86_64-darwin"`
 - host os: `Darwin 24.1.0, macOS 10.16`
 - multi-user?: `yes`
 - sandbox: `no`
 - version: `nix-env (Nix) 2.24.10`
 - channels(root): `"nixpkgs"`
 - nixpkgs: `/nix/var/nix/profiles/per-user/root/channels/nixpkgs`
edited: I just noticed it says macOS 10.16, I’m on Sequoia 15.1
Nix was installed using sh <(curl -L https://nixos.org/nix/install) to a clean machine.
Here are my files (~/nixconfig)
flake.nix
  description = "Worka's Darwin system flake";
    nix-darwin = {
      url = "github:LnL7/nix-darwin";
    home-manager = {
  outputs = { self, nixpkgs, nix-darwin, home-manager }:
      darwinUser = builtins.getEnv "DARWIN_USER";
      darwinHost = builtins.getEnv "DARWIN_HOST";
      workaDarwinSystem = { hostname, username }: nix-darwin.lib.darwinSystem {
        system = "x86_64-darwin";
        modules = [
          ./configuration.nix
          home-manager.darwinModules.home-manager
            networking.hostName = hostname;
            users.users.${username}.home = "/Users/${username}";
            home-manager.users.${username} = { pkgs, lib, ... }:
              import ./home.nix { inherit pkgs lib username; };
        specialArgs = {
          inherit (nixpkgs) lib;
          inherit username;
      darwinConfigurations.${darwinHost} = workaDarwinSystem {
        hostname = darwinHost;
        username = darwinUser;
home.nix
{ pkgs, lib, username, ... }:
  home.packages = with pkgs; [
    neovim
    git
    tree
    ripgrep
    fd
    jq
  home.username = username;
  home.homeDirectory = lib.mkForce "/Users/${username}";
  home.stateVersion = "24.05";
  # home-manager enable
configuration.nix
{ pkgs, ... }:
    vim
    git
  services.nix-daemon.enable = true;
  nix.package = pkgs.nix;
  # zsh enable
  programs.zsh.enable = true;
  # allows unfree packages to be installed
  # Finder settings
  system.defaults.finder = {
    AppleShowAllExtensions = true;
    AppleShowAllFiles = true;
    CreateDesktop = false;
    FXEnableExtensionChangeWarning = false;
    ShowPathbar = true;
    ShowStatusBar = true;
  # Dock setting
  system.defaults.dock = {
    autohide = true;
    show-recents = false;
    tilesize = 50;
    magnification = true;
    largesize = 64;
    orientation = "bottom";
    mineffect = "scale";
    launchanim = false;
  system.stateVersion = 5;
  nixpkgs.hostPlatform = "x86_64-darwin";
As per nix-darwin documentation the next step is to run this command:
nix run nix-darwin -- switch --flake ~/.config/nix-darwin which I adjust to match the nix run nix-darwin -- switch --flake ~/nixconfig
I tried also with nix run nix-darwin --extra-experimental-features "nix-command flakes" -- switch --flake ~/nixconfig.
Error:
error: flake ‘git+file:///Users/worka/nixconfig’ does not provide attribute ‘packages.x86_64-darwin.darwinConfigurations.Workas-MacBook-Pro.system’, ‘legacyPackages.x86_64-darwin.darwinConfigurations.Workas-MacBook-Pro.system’ or ‘darwinConfigurations.Workas-MacBook-Pro.system’
echo $DARWIN_USER & $DARWIN_HOST is correct.
What went wrong?
Or rather what should I do next if I want to have home-manager installed correctly?
Thanks in advance.
Reinstalled with Determinate System Nix + redo config files using template = WORKING!
