Flake that works in repl, but not when building
The following flake.nix works fine when I load it using nix repl, but not when I try to build it with nix build.
    nixpkgs.url = "github:nixos/nixpkgs/";
      with nixpkgs.legacyPackages.x86_64-linux;
        isArthur = pkg:
          pkg.name == "arthur" && pkg.os == "linux" && pkg.arch == "amd64";
        packages.arthur = stdenv.mkDerivation rec {
          pname = "arthur";
          src = fetchurl {
            url =
              "s3://manifests/stable/manifest.json?region=eu-central-1";
            sha256 =
              "sha256:17bd9djdp5401ixglbw7jxw4a06w01imcc36n3dzrxiapfnarrny";
          manifest = builtins.fromJSON (builtins.readFile src.outPath);
          version = manifest.version;
          arthur_pkg =
            builtins.elemAt (builtins.filter isArthur manifest.packages) 0;
          dontUnpack = true;
          dontBuild = true;
          installPhase = ''
            echo $version
        defaultPackage = self.packages.${system}.arthur;
In nix repl:
% nix repl
Welcome to Nix 2.6.0. Type :? for help.
nix-repl> :lf .
warning: Git tree '/home/haddock/projs/arthur-v2' is dirty
Added 10 variables.
nix-repl> outputs.defaultPackage.x86_64-linux.arthur_pkg
[0/1 built] { arch = "amd64"; executable = true; name = "arthur"; os = "linux"; public = false; sha256 = "10ffce33013f8106a51f0b06812df17876b1197aca97b78f1b4b248b072c6dd0"; size = 5283721; }
but when trying to build it:
% nix build
error: cannot coerce a set to a string
       at /nix/store/cxdpw8siygg8vp9w07i703lvkgm9889z-source/flake.nix:24:11:
           23|           version = manifest.version;
           24|           arthur_pkg =
           25|             builtins.elemAt (builtins.filter isArthur manifest.packages) 0;
I’m not sure what’s going on here, why the attempt to coerce it to a string a all?
Try evaluating with --impure which I think the repl does. If that works then the error is caused by differences between impure and pure evaluation.
No, unfortunately nix build --impure has the same behaviour as nix build :disappointed:
Hosted by Flying Circus.
