Flutter direnv works well in terminal but not works with vscode-direnv
flake.nix
  description = "A basic flake with a shell";
  inputs.nixpkgs.url = "github:NixOS/nixpkgs/nixpkgs-unstable";
        pkgs = import nixpkgs {
          inherit system;
          config = {
            android_sdk.accept_license = true;
            allowUnfree = true;
        buildToolsVersion = "33.0.2";
        androidComposition = pkgs.androidenv.composeAndroidPackages
            buildToolsVersions = [ buildToolsVersion ];
            platformVersions = [ "31" "33" ];
            abiVersions = [ "armeabi-v7a" "arm64-v8a" "x86_64" ];
            includeSystemImages = true;
            includeEmulator = true;
            useGoogleAPIs = true;
        androidSdk = androidComposition.androidsdk;
        devShells.default =
          with pkgs; mkShell {
            ANDROID_SDK_ROOT = "${androidSdk}/libexec/android-sdk";
            packages = [
              bashInteractive
              flutter
              androidSdk
              jdk11
.envrc
if ! has nix_direnv_version || ! nix_direnv_version 2.3.0; then
    source_url "https://raw.githubusercontent.com/nix-community/nix-direnv/2.3.0/direnvrc" "sha256-Dmd+j63L84wuzgyjITIfSxSD57Tx7v51DMxVZOsiUD8="
fi
use flake
flutter doctor by vscode extension
[flutter] flutter doctor -v
[✓] Flutter (Channel stable, 3.10.5, on NixOS 23.11 (Tapir) 6.4.7-zen1, locale en_US.UTF-8)
    • Flutter version 3.10.5 on channel stable at /nix/store/d5phjwalnggcbab5qwbm6knfmghi6knf-flutter-3.10.5-unwrapped
    • Upstream repository https://github.com/flutter/flutter.git
    • Framework revision 796c8ef792 (8 周前), 2023-06-13 15:51:02 -0700
    • Engine revision 45f6e00911
    • Dart version 3.0.5
    • DevTools version 2.23.1
[!] Android toolchain - develop for Android devices (Android SDK version 33.0.2)
    • Android SDK at /nix/store/czaracamshrsnd4jkkcics6q8z9m24zd-androidsdk/libexec/android-sdk
    • Platform android-33, build-tools 33.0.2
    • ANDROID_SDK_ROOT = /nix/store/czaracamshrsnd4jkkcics6q8z9m24zd-androidsdk/libexec/android-sdk
    • Java binary at: /nix/store/59i7hzgwjpg4g7xy2wh9v78163g7x5zf-android-studio-stable-2022.3.1.18-unwrapped/jbr/bin/java
    • Java version OpenJDK Runtime Environment (build 17.0.6+0-17.0.6b829.9-10027231)
    ! Some Android licenses not accepted. To resolve this, run: flutter doctor --android-licenses
[✗] Chrome - develop for the web (Cannot find Chrome executable at google-chrome)
    ! Cannot find Chrome. Try setting CHROME_EXECUTABLE to a Chrome executable.
[✗] Linux toolchain - develop for Linux desktop
    ✗ clang++ is required for Linux development.
      It is likely available from your distribution (e.g.: apt install clang), or can be downloaded from https://releases.llvm.org/
    ✗ CMake is required for Linux development.
      It is likely available from your distribution (e.g.: apt install cmake), or can be downloaded from https://cmake.org/download/
    ✗ ninja is required for Linux development.
      It is likely available from your distribution (e.g.: apt install ninja-build), or can be downloaded from https://github.com/ninja-build/ninja/releases
    ✗ pkg-config is required for Linux development.
      It is likely available from your distribution (e.g.: apt install pkg-config), or can be downloaded from https://www.freedesktop.org/wiki/Software/pkg-config/
[✓] Android Studio (version 2022.3)
    • Android Studio at /nix/store/59i7hzgwjpg4g7xy2wh9v78163g7x5zf-android-studio-stable-2022.3.1.18-unwrapped
    • Flutter plugin can be installed from:
      🔨 https://plugins.jetbrains.com/plugin/9212-flutter
    • Dart plugin can be installed from:
      🔨 https://plugins.jetbrains.com/plugin/6351-dart
[✓] IntelliJ IDEA Ultimate Edition (version 2023.2)
    • IntelliJ at /nix/store/y2y48l37qi8sx8dsy10cf86flgli3n8z-idea-ultimate-2023.2/idea-ultimate
    • Flutter plugin version 75.1.4
[✓] Connected device (1 available)
    • Linux (desktop) • linux • linux-x64 • NixOS 23.11 (Tapir) 6.4.7-zen1
    ! Device emulator-5554 is offline.
[✓] Network resources
    • All expected network resources are available.
! Doctor found issues in 3 categories.
exit code 0
flutter doctor -v in terminal
 impure  ~/C/news_app  flutter doctor -v        nix-shell-env
    • Java binary at: /nix/store/wp16ly0sx6k064a0kjr6kp8m6mf58a20-openjdk-11.0.19+7/lib/openjdk/bin/java
    • Java version OpenJDK Runtime Environment (build 11.0.19+0-adhoc..source)
[✓] Linux toolchain - develop for Linux desktop
    • clang version 11.1.0
    • cmake version 3.26.4
    • ninja version 1.11.1
    • pkg-config version 0.29.2
[!] Android Studio (version 2022.3)
    ✗ Failed to run Java: ProcessException: No such file or directory
        Command: /nix/store/59i7hzgwjpg4g7xy2wh9v78163g7x5zf-android-studio-stable-2022.3.1.18-unwrapped/jbr/bin/java -version
    ✗ Unable to determine bundled Java version.
    • Try updating or re-installing Android Studio.
vscode installed by home-manager
  programs = {
    vscode = {
      package = pkgs.vscode.fhs;
This may be related to this (assuming this is the extension you are using): GitHub - direnv/direnv-vscode: unclutter your .profile.
See “Known Issues”
I have fixed by installing flutter by asdf and setting the flutter sdk path to asdf flutter path, and installing android sdk by direnv
but the flutter of asdf missing some Linux dependencies
