I tried building but nginx won’t build.
Could I disable vod?
/nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/hls/adts_encoder_filter.c
/nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/subtitle/dfxp_format.c: In function 'dfxp_parse':
/nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/subtitle/dfxp_format.c:443:17: error: 'recovery' is deprecated [-Werror=deprecated-declarations]
443 | (!ctxt->wellFormed && !ctxt->recovery))
In file included from /nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/subtitle/dfxp_format.c:6:
/nix/store/rdnx32wkaz273f643sv1m1hbd5gh56bz-libxml2-2.14.3-dev/include/libxml2/libxml/parser.h:377:9: note: declared here
377 | int recovery XML_DEPRECATED_MEMBER;
gcc -c -pipe -O -W -Wall -Wpointer-arith -Wno-unused-parameter -Werror -g -DNDK_SET_VAR -DNDK_UPSTREAM_LIST -I src/core -I src/event -I src/event/modules -I src/event/quic -I src/os/unix -I /nix/store/2ysp5ichpccf4lv1wp2qcwz0bmm840f1-rtmp -I /nix/store/w218m7m6bma3n6hnk15wxw5fd7sn9y7x-develkit/objs -I objs/addon/ndk -I /usr/include/libxml2 -I objs -I src/http -I src/http/modules -I src/http/v2 -I /nix/store/w218m7m6bma3n6hnk15wxw5fd7sn9y7x-develkit/src -I /nix/store/w218m7m6bma3n6hnk15wxw5fd7sn9y7x-develkit/src -I /nix/store/w218m7m6bma3n6hnk15wxw5fd7sn9y7x-develkit/objs -I objs/addon/ndk -I /usr/include/libxml2 -I src/stream \
-o objs/addon/hls/buffer_filter.o \
/nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/hls/buffer_filter.c
-o objs/addon/hls/frame_joiner_filter.o \
/nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/hls/frame_joiner_filter.c
-o objs/addon/hls/hls_muxer.o \
/nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/hls/hls_muxer.c
-o objs/addon/hls/id3_encoder_filter.o \
/nix/store/xjls3h70j5zj2pipyvlhl1zwd4c14wf8-vod/vod/hls/id3_encoder_filter.c
cc1: all warnings being treated as errors
make[1]: *** [objs/Makefile:2686: objs/addon/subtitle/dfxp_format.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/build/nginx-1.28.0'
make: *** [Makefile:10: build] Error 2
(END)
config:
{ config, ... }:
services.frigate = {
hostname = "localhost";
settings = {
mqtt.enabled = false;
record = {
enabled = true;
retain = {
days = 2;
mode = "all";
# ffmpeg.hwaccel_args = "preset-vaapi";
cameras.cam-1 = {
ffmpeg.inputs = [
path = "rtsp://admin:admin@192.168.1.5:554/profile1";
roles = [ "record" ];
detect.enabled = false;
record.enabled = true;
source:
