I’m considering to migrate my pi fleet (and other small, less powerful systems) to nixos; they fall in roughly two categories:
- semi embedded servers/appliances (e.g. running smarthome things like home-assistant or webthings, no interactive user accounts) => no significant writable storage and/or imperative configuration needed
- “thick terminals”, UI machines that need to allow for multiple users doing some personal config stuff (e.g. via home-manager), will typically additionally run remote-desktop sessions or e.g.
vscode
remote if/when dev-power is needed. These systems will be still limited by (typically) only having SD-card storage.
I found a few projects that focus on cross-compiling and building ready-to deploy images, which would pretty much cover case (1)
- which one would be recommended (ease of use/features/recent)?
Would it be possible to combine read-only images (semi-embedded) with case (2)? Anyway because of resource constraints one would want to somehow produce user’s HM configs in that case on a remote host (with x-compiling as necessary) and copy the derivations over to the store of the semi-embedded host automatically/transparently.
I intend to orchestrate deployments from one build machine (x86-64) and keep the configs per target machine in git.
You could use nixos-rebuild
with --target-host
argument to build the configuration locally (probably using remote builders), push full closure to the remote machine over SSH and then either activate it (with switch
) or make it boot after reboot (with boot
), just like with local use of nixos-rebuild
You can also use --build-host
argument to specify specific remote host to use for building the configuration.
home-manager
doesn’t support such remote activation on its own, but will work if it is configured as part of NixOS config. You could also manually build HM configuration with home-manager build
, then push it to the remote host with nix copy
and activate it there by calling /nix/store/.../activate
There is also a tool in development by @Solene called bento
that automates all this and could be of use: Solene'%
@YorikSar thanks for your pointers, I’ll look into it (a bit time-strapped now, hope soon-ish).
It appears the two main categories are still useful, since “just copying the nix store” will mean that there are still nix-operations (e.g. garbage collect) that need to be done on the client machine. But I suppose that’s what comes with wanting the cake (of configurable user envs on the target) and eat it means.
I was already thinking about bento
, but didn’t want to decide too early since I wanted to try to use only one tool/technology for remote nix host management and haven’t gotten around to do the transition yet. (Now I’m using ansible
to push /etc/nixos
to my servers and just do nixos-rebuild
with it too. My desktops/laptops are already flake-based).
Then for the more embedded variant, I think I’ll go the image route anyway.
I’ll report back my experiences later
