General help with config
hi all, I am new to Nixos and have spent a while recreating my previous configs in Nixos and have now moved to it on my spare laptop. and i would just like some general config advice. my top priority at the moment is trying to move the config to nix-unstable as it seems to me most like a rolling release which works best for me. but for whatever reason my laptop is stuck on 25.05. this is preventing me using things like kando menu which is a version behind. this is especially odd as according to the nix search the 25.05 channel should have the newest version so i may even be on 24.11. any help or general config tips would be great. thanks.
here is my config on github:
In your configuration.nix :
system.stateVersion = “unstable”; ← not sure that is actually an option?
system.stateVersion = “25.05”; <— try that (maybe 25.11 now?)
That system.stateVersion = should have come with a warning and a guide to read… you should read it.
Here you go:
Summary
This option defines the first version of NixOS you have installed on this particular machine, and is used to maintain compatibility with application data (e.g. databases) created on older NixOS versions.
For example, if NixOS version XX.YY ships with AwesomeDB version N by default, and is then upgraded to version XX.YY+1, which ships AwesomeDB version N+1, the existing databases may no longer be compatible, causing applications to fail, or even leading to data loss.
The stateVersion mechanism avoids this situation by making the default version of such packages conditional on the first version of NixOS you’ve installed (encoded in stateVersion), instead of simply always using the latest one.
Note that this generally only affects applications that can’t upgrade their data automatically - applications and services supporting automatic migrations will remain on latest versions when you upgrade.
Most users should never change this value after the initial install, for any reason, even if you’ve upgraded your system to a new NixOS release.
This value does not affect the Nixpkgs version your packages and OS are pulled from, so changing it will not upgrade your system.
This value being lower than the current NixOS release does not mean your system is out of date, out of support, or vulnerable.
Do not change this value unless you have manually inspected all the changes it would make to your configuration, and migrated your data accordingly.
Basically it’s not the version of your OS but the version of your config file that was used when created.
Your Flake.nix is using nixpkgs.url = “github:NixOs/nixpkgs/nixos-unstable”; so you’re using the “unstable” (latest) version for all your packages.
Your Home Manager is following that.
You probably just need to use --upgrade , when using sudo nixos-rebuild switch --flake . --upgrade (or whatever you’re using to build)
It’s not.
NixOS will error out with that setting if you’re actually on 25.05 now, so you’re probably on 24.11 still, please actually update.
Yeah sorry that’s a version from when I was trying to get it to work, “unstable” isn’t an option I changed it after that crashed to 25.05 and forgot to push. I don’t think I’ve rebuilt with --update so will try that when I get home.
Thanks for the speedy response and any other general tips for my config would be greatly appreciated :+1::+1:
