Ghost Wired connection 2 failed to connect on KDE plasma
Every like hour? or idk I get prompted for an admin password and it says failed to connect to Wired connection 2. I’ve changed nothing in my config to do with networking, I can’t pinpoint when this began but I can’t find anything in my config about it.
nmcli device status yields this:
enp14s0  ethernet  connected               Wired connection 1
lo       loopback  connected (externally)  lo
journalctl -xeu NetworkManager yields this:
Mär 20 17:42:27 nixHomeDesktop NetworkManager[1120]: <warn>  [1742488947.8432] platform-linux: do-add-ip6-address[6: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 17:42:27 nixHomeDesktop NetworkManager[1120]: <warn>  [1742488947.8433] l3cfg[de2ec6da2893d73f,ifindex=6]: unable to configure IPv6 route: type unicast fe80::/64 dev 6 metric 1024 mss 0 rt-src ipv6ll
Mär 20 18:12:29 nixHomeDesktop NetworkManager[1120]: <warn>  [1742490749.1472] platform-linux: do-add-ip6-address[7: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 18:12:29 nixHomeDesktop NetworkManager[1120]: <warn>  [1742490749.1473] l3cfg[e0d3f091b26bd8e0,ifindex=7]: unable to configure IPv6 route: type unicast fe80::/64 dev 7 metric 1024 mss 0 rt-src ipv6ll
Mär 20 18:42:30 nixHomeDesktop NetworkManager[1120]: <warn>  [1742492550.6814] platform-linux: do-add-ip6-address[8: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 18:42:30 nixHomeDesktop NetworkManager[1120]: <warn>  [1742492550.6815] l3cfg[b2ed9b10af4a8f0b,ifindex=8]: unable to configure IPv6 route: type unicast fe80::/64 dev 8 metric 1024 mss 0 rt-src ipv6ll
Mär 20 19:12:31 nixHomeDesktop NetworkManager[1120]: <warn>  [1742494351.9645] platform-linux: do-add-ip6-address[9: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 19:12:31 nixHomeDesktop NetworkManager[1120]: <warn>  [1742494351.9645] l3cfg[b2ed9b10af4a8f0b,ifindex=9]: unable to configure IPv6 route: type unicast fe80::/64 dev 9 metric 1024 mss 0 rt-src ipv6ll
Mär 20 21:42:38 nixHomeDesktop NetworkManager[1120]: <warn>  [1742503358.5824] platform-linux: do-add-ip6-address[14: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 21:42:38 nixHomeDesktop NetworkManager[1120]: <warn>  [1742503358.5825] l3cfg[9d7242a76549e2c4,ifindex=14]: unable to configure IPv6 route: type unicast fe80::/64 dev 14 metric 1024 mss 0 rt-src ipv6ll
Mär 20 22:12:39 nixHomeDesktop NetworkManager[1120]: <warn>  [1742505159.8504] platform-linux: do-add-ip6-address[15: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 22:12:39 nixHomeDesktop NetworkManager[1120]: <warn>  [1742505159.8505] l3cfg[8e863a49dba48b21,ifindex=15]: unable to configure IPv6 route: type unicast fe80::/64 dev 15 metric 1024 mss 0 rt-src ipv6ll
Mär 20 22:42:41 nixHomeDesktop NetworkManager[1120]: <warn>  [1742506961.1233] platform-linux: do-add-ip6-address[16: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 22:42:41 nixHomeDesktop NetworkManager[1120]: <warn>  [1742506961.1233] l3cfg[49135b207a5d798a,ifindex=16]: unable to configure IPv6 route: type unicast fe80::/64 dev 16 metric 1024 mss 0 rt-src ipv6ll
Mär 20 23:12:42 nixHomeDesktop NetworkManager[1120]: <warn>  [1742508762.6516] platform-linux: do-add-ip6-address[17: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 20 23:12:42 nixHomeDesktop NetworkManager[1120]: <warn>  [1742508762.6517] l3cfg[4117efa0ca62400c,ifindex=17]: unable to configure IPv6 route: type unicast fe80::/64 dev 17 metric 1024 mss 0 rt-src ipv6ll
Mär 21 00:12:45 nixHomeDesktop NetworkManager[1120]: <warn>  [1742512365.2030] platform-linux: do-add-ip6-address[19: fe80::44f7:97e2:b9f:f47b]: failure 19 (No such device - ipv6: Unable to find the interface)
Mär 21 00:12:45 nixHomeDesktop NetworkManager[1120]: <warn>  [1742512365.2030] l3cfg[4117efa0ca62400c,ifindex=19]: unable to configure IPv6 route: type unicast fe80::/64 dev 19 metric 1024 mss 0 rt-src ipv6ll
Nevermind this was a DJI action camera I had plugged in that was trying to create a network
