gtk.cursorTheme.name gives errors when rebuilt as part of system
I have noticed a bizarre quirk of home manager. Namely, I have this in my home.nix file:
{ config, pkgs, ... }:
  # Home Manager needs a bit of information about you and the paths it should
  # manage.
  home.username = "fusion809";
  home.homeDirectory = "/home/fusion809";
  # This value determines the Home Manager release that your configuration is
  # compatible with. This helps avoid breakage when a new Home Manager release
  # introduces backwards incompatible changes.
  # You should not change this value, even if you update Home Manager. If you do
  # want to update the value, then make sure to first check the Home Manager
  # release notes.
  home.stateVersion = "24.11"; # Please read the comment before changing.
  # The home.packages option allows you to install Nix packages into your
  # environment.
  home.packages = [
    # # Adds the 'hello' command to your environment. It prints a friendly
    # # "Hello, world!" when run.
    # pkgs.hello
    # # It is sometimes useful to fine-tune packages, for example, by applying
    # # overrides. You can do that directly here, just don't forget the
    # # parentheses. Maybe you want to install Nerd Fonts with a limited number of
    # # fonts?
    # (pkgs.nerdfonts.override { fonts = [ "FantasqueSansMono" ]; })
    # # You can also create simple shell scripts directly inside your
    # # configuration. For example, this adds a command 'my-hello' to your
    # # environment:
    # (pkgs.writeShellScriptBin "my-hello" ''
    #   echo "Hello, ${config.home.username}!"
  # Home Manager is pretty good at managing dotfiles. The primary way to manage
  # plain files is through 'home.file'.
  home.file = {
    # # Building this configuration will create a copy of 'dotfiles/screenrc' in
    # # the Nix store. Activating the configuration will then make '~/.screenrc' a
    # # symlink to the Nix store copy.
    # ".screenrc".source = dotfiles/screenrc;
    # # You can also set the file content immediately.
    # ".gradle/gradle.properties".text = ''
    #   org.gradle.console=verbose
    #   org.gradle.daemon.idletimeout=3600000
  # Home Manager can also manage your environment variables through
  # 'home.sessionVariables'. These will be explicitly sourced when using a
  # shell provided by Home Manager. If you don't want to manage your shell
  # through Home Manager then you have to manually source 'hm-session-vars.sh'
  # located at either
  #  ~/.nix-profile/etc/profile.d/hm-session-vars.sh
  # or
  #  ~/.local/state/nix/profiles/profile/etc/profile.d/hm-session-vars.sh
  # or
  #  /etc/profiles/per-user/fusion809/etc/profile.d/hm-session-vars.sh
  home.sessionVariables = {
    EDITOR = "vim";
  # Let Home Manager install and manage itself.
  programs.git = {
    userName = "fusion809";
    userEmail = "brentonhorne77@gmail.com";
  programs.bash = {
    bashrcExtra = "
function sbash {
	source $HOME/.bashrc
function vcf {
	sudo vim /etc/nixos/configuration.nix
function nixcg {
	sudo nix-collect-garbage -d
function nixcu {
	sudo nix-channel --update
function nixrsu {
	sudo nixos-rebuild switch --upgrade
function update {
	nixcu
	nixrsu
	nixcg
function rebuild {
alias nixrb=rebuild
  programs.zsh = {
    initExtra = "
source $HOME/NixOS-configs/hnixos.zsh-theme
function szsh {
	source $HOME/.zshrc
function clipf {
	xclip -sel clip < $1
function rainbowfastfetch {
	hyfetch -p rainbow -b fastfetch --args='--localip-show-ipv4 false'
export NIXPKGS_ALLOW_INSECURE=1
function sclipf {
	sudo xclip -sel clip < $1
function git-branch {
  if ! [[ -n \"$1\" ]]; then
        git rev-parse --abbrev-ref HEAD
  else
        git -C \"$1\" rev-parse --abbrev-ref HEAD
  fi
function push {
	git add --all
	git commit -m \"$@\"
	git push origin $(git-branch)
function cdnc {
	cd $HOME/NixOS-configs/$1
function hmr {
        home-manager switch
 programs.gnome-shell.theme.name = "WhiteSur-Dark-solid";
 gtk.theme.name = "WhiteSur-Dark-solid";
 gtk.iconTheme.name = "WhiteSur-Dark";
 gtk.cursorTheme.name = "WhiteSur-cursors";
Interestingly, when I build this config with home-manager switch, I get no errors. But when I import it into my system configuration.nix file with this start to that file:
  imports =
      ./hardware-configuration.nix
      ./home.nix
I get this error from nixos-rebuild switch:
error:
       … while evaluating the attribute 'config'
         at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:1:12284:
       … while calling the 'seq' builtin
         at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:1:12293:
       error: The option `gtk.cursorTheme' does not exist. Definition values:
       - In `/home/fusion809/NixOS-configs/home.nix':
building Nix...
any ideas what I need to do to this fix this error?
Because you need to import home manager first and pass it as a home manager import.
See: Home Manager Manual
The imports = part of my configuration.nix is now:
  imports =
      <home-manager/nixos>
      ./home.nix
Which I added based on this part of that manual:
Was this what I was meant to do? It’s not fixing the error, so I’m guessing not.
Now you need to move home.nix to home-manager like:
home-manager.users.username = {
        imports =
            home.nix
Where you need to substitute username with your username.
Hmm, I renamed home.nix as home-manager.nix and replaced home. in it with it home-manager. as I thought that’s what you meant (at most, I wasn’t sure whether you also meant renaming the file). And yes, I updated /etc/nixos/configuration.nix to incorporate this new home-manager.nix file. Yet I still get the error:
       - In `/home/fusion809/NixOS-configs/home-manager.nix':
from rebuilding my system.
Before you changed anything your configuration.nix should have looked something like this:
imports =
        imports =
            ./home.nix
But you need to change the username according the one you create in your config.
Now it’s complaining about the }; at the end of this code snippet I quoted giving this error:
      error: syntax error, unexpected '}', expecting ';'
       at /home/fusion809/NixOS-configs/configuration.nix:18:3:
           17|           ]
           18|   };
Because I missed a semicolon at the end of the line before. I edit my post accordingly.
Now it’s giving the error:
error: undefined variable 'home'
       at /home/fusion809/NixOS-configs/configuration.nix:16:13:
           15|           [
           16|             home.nix
           17|           ];
Does home.nix need to be in quotes?
It probably needs to be ./home.nix
Now I am getting this error:
error: The option `home-manager.users.fusion809.programs.home' does not exist. Definition values:
Is there a nice simple way to change all the settings over to suit the system configuration file? Or is this going to be a tedious matter of looking them all up in the documentation and changing them from there?
I only used home-manger in my NixOS configuration before. But if I recall correctly you should not need to change your home.nix in between stand alone and as a module. So you say that your home.nix works fine when using it with stand alone home-manager? Can you post it?
Sure, here it is. NixOS-configs/home.nix at f47cebf9ba541963916b057d5a044fd94c29c338 · fusion809/NixOS-configs · GitHub
And yes it builds fine with home-manager.
Oops, my apologies @eblechschmidt. I had done a mass replace of home-manager with home in this file and it was responsible for this error. I had previously had programs.home-manager.enable = true; but that became programs.home.enable = true; which was causing this error. It now builds fine, including as part of my system config. Thank you for your help!
No worries. Would you maybe mark the answer above as the solution so some else that stumbles upon this finds it easier to find the solution?
I marked this one as the solution as it included the final fix I needed.
