GTK portal does not provide Settings
I’ve been trying to get everything working with my Hyprland setup. Well, everything basically works, but the desktop portal of last resort (xdg-desktop-portal-gtk) does not provide some of the interfaces, such as org.freedesktop.portal.Settings. For example, when starting Chrome, I get this warning:
(google-chrome:6127): Gdk-WARNING **: 00:30:12.935: Failed to read portal settings: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.portal.Settings” on object at path /org/freedesktop/portal/desktop
I think Settings is the interface that provides information like the light/dark mode preference.
This used to be the upstream default in xdg-desktop-portal-gtk before version 1.5.1 when building without GNOME, but then people realized these interfaces are not supposed to be in any way Gnome specific:
It looks like the Nix recipe still disables those interfaces. I tried to override this setting, but it somehow broke antialiasing in at least Firefox, Chrome and wofi. I don’t quite understand what’s going on with that.
How do people running with xdg-desktop-portal-gtk set their light/dark preference? Do you actually have a portal that implements org.freedesktop.portal.Settings? (AppChooser is another missing interface.)
I’m in the same boat. I’m running sway and have both the wlr and gtk portals enabled. Settings seems unqueryable and as a result most gnome services dont work (gnome calendar, mail, gtk4 dark/light, etc). Any luck with fixes?
Same issue here with firefox.
Use the -gnome portal instead.
