"hash mismatch in fixed-output derivation" issue with portmod
I was hoping to update Portmod to the latest release version 2.1.0 but have ran into a problem. Any ideas what would cause this?
I’m new to this and all I’ve done is change the main SHA265 and version number here: nixpkgs/default.nix at 884018a4fbe4d4096addf3dec0bfdb743b933b74 · 1MachineElf/nixpkgs · GitHub
Unfortunately, I cannot seem to build it properly. There is an error about an unexpected hash value for a derivation with name ending in portmod-rust-2.1.0-vendor.tar.gz. Here’s the error:
shrinking RPATHs of ELF executables and libraries in /nix/store/vyn3v2m1h97f7ci4n05f6gifyy412by2-portmod-rust-2.1.0-vendor.tar.gz
strip is /nix/store/4g5fidyk19akng9n91cql60ylrjq93s6-gcc-wrapper-10.3.0/bin/strip
patching script interpreter paths in /nix/store/vyn3v2m1h97f7ci4n05f6gifyy412by2-portmod-rust-2.1.0-vendor.tar.gz
checking for references to /build/ in /nix/store/vyn3v2m1h97f7ci4n05f6gifyy412by2-portmod-rust-2.1.0-vendor.tar.gz...
hash mismatch in fixed-output derivation '/nix/store/xmd699jbrps4m58n78v4z4qhciapf3y8-portmod-rust-2.1.0-vendor.tar.gz':
  wanted: sha256:1g9faqbqzh9nf71kgzdsn8ih83riyw13cbf8mz3qipv0d5k2225l
  got:    sha256:1cd8ycwh27ma9zmkcaw2xiv3v95qhdhs1nkmvq0qnjcnjhrcqiyw
cannot build derivation '/nix/store/vga44rn4vb8l0rsdf6l7bndlbam7iqzs-portmod-rust-2.1.0.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/d1h4nm819xm9g2fhk7kdwsxsc6amzc9b-portmod-2.1.0.drv': 1 dependencies couldn't be built
error: build of '/nix/store/d1h4nm819xm9g2fhk7kdwsxsc6amzc9b-portmod-2.1.0.drv' failed
Slightly edited full output below:
[me@x570-nixos:~/nixpkgs-portmod]$ nix-env -i portmod -f /home/evan/nixpkgs-portmod --show-trace
installing 'portmod-2.1.0'
  /nix/store/s6gdqbjyvzq0g9mi99dw39k3r8ma4bq5-portmod-rust-2.1.0-vendor.tar.gz.drv
building '/nix/store/s6gdqbjyvzq0g9mi99dw39k3r8ma4bq5-portmod-rust-2.1.0-vendor.tar.gz.drv'...
unpacking sources
unpacking source archive /nix/store/261lz9jfhiv6csb56fdwqw059gq6sw9p-source
source root is source
patching sources
configuring
building
    Updating crates.io index
 Downloading crates ...
  Downloaded crossbeam-utils v0.8.5
  Downloaded fnv v1.0.7
  Downloaded hashbrown v0.11.2
  Downloaded no..m v6.2.1
  Downloaded ntapi v0.3.6
  Downloaded syn v1.0.75
  Downloaded winapi-i686-pc-windows-gnu v0.4.0
  Downloaded winapi-x86_64-pc-windows-gnu v0.4.0
   Vendoring Inflector v0.11.4 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/Inflector-0.11.4) to portmod-rust-2.1.0-vendor.tar.gz/Inflector
   Vendoring aho-corasick v0.7.15 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/aho-corasick-0.7.15) to portmod-rust-2.1.0-vendor.tar.gz/aho-corasick
   Vendoring arc-swap v1.3.1 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/arc-swap-1.3.1) to portmod-rust-2.1.0-vendor.tar.gz/arc-swap
   Vendoring arrayref v0.3.6 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/arrayref-0.3.6) to portmod-rust-2.1.0-vendor.tar.gz/arrayref
   Vendoring arrayvec v0.5.2 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/arrayvec-0.5.2) to portmod-rust-2.1.0-vendor.tar.gz/arrayvec-0.5.2
   Vendoring arrayvec v0.7.1 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/arrayvec-0.7.1) to portmod-rust-2.1.0-vendor.tar.gz/arrayvec
   Vendoring autocfg v1.0.1 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/autocfg-1.0.1) to portmod-rust-2.1.0-vendor.tar.gz/autocfg
   Vendoring bitflags v1.3.2 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/bitflags-1.3.2) to portmod-rust-2.1.0-vendor.tar.gz/bitflags
   Vendoring bitvec v0.19.5 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/bitvec-0.19.5) to portmod-rust-2.1.0-vendor.tar.gz/bitvec
   Vendoring blake2 v0.9.1 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/blake2-0.9.1) to portmod-rust-2.1.0-vendor.tar.gz/blake2
   Vendoring blake3 v1.0.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/blake3-1.0.0) to portmod-rust-2.1.0-vendor.tar.gz/blake3
   Vendoring block-buffer v0.9.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/block-buffer-0.9.0) to portmod-rust-2.1.0-vendor.tar.gz/block-buffer
   Vendoring bstr v0.2.15 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/bstr-0.2.15) to portmod-rust-2.1.0-vendor.tar.gz/bstr
   Vendoring bumpalo v3.7.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/bumpalo-3.7.0) to portmod-rust-2.1.0-vendor.tar.gz/bumpalo
   Vendoring cassowary v0.3.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/cassowary-0.3.0) to portmod-rust-2.1.0-vendor.tar.gz/cassowary
   Vendoring cc v1.0.69 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/cc-1.0.69) to portmod-rust-2.1.0-vendor.tar.gz/cc
   Vendoring cfg-if v1.0.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/cfg-if-1.0.0) to portmod-rust-2.1.0-vendor.tar.gz/cfg-if
   Vendoring constant_time_eq v0.1.5 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/constant_time_eq-0.1.5) to portmod-rust-2.1.0-vendor.tar.gz/constant_time_eq
   Vendoring convert_case v0.4.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/convert_case-0.4.0) to portmod-rust-2.1.0-vendor.tar.gz/convert_case
   Vendoring cpufeatures v0.1.5 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/cpufeatures-0.1.5) to portmod-rust-2.1.0-vendor.tar.gz/cpufeatures
   Vendoring crossbeam-channel v0.5.1 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/crossbeam-channel-0.5.1) to portmod-rust-2.1.0-vendor.tar.gz/crossbeam-channel
   Vendoring crossbeam-deque v0.8.1 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/crossbeam-deque-0.8.1) to portmod-rust-2.1.0-vendor.tar.gz/crossbeam-deque
   Vendoring crossbeam-epoch v0.9.5 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/crossbeam-epoch-0.9.5) to portmod-rust-2.1.0-vendor.tar.gz/crossbeam-epoch
   Vendoring crossbeam-utils v0.8.5 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/crossbeam-utils-0.8.5) to portmod-rust-2.1.0-vendor.tar.gz/crossbeam-utils
   Vendoring crossterm v0.20.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/crossterm-0.20.0) to portmod-rust-2.1.0-vendor.tar.gz/crossterm
   Vendoring crossterm_winapi v0.8.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/crossterm_winapi-0.8.0) to portmod-rust-2.1.0-vendor.tar.gz/crossterm_winapi
   Vendoring wasm-bindgen-backend v0.2.76 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/wasm-bindgen-backend-0.2.76) to portmod-rust-2.1.0-vendor.tar.gz/wasm-bindgen-backend
   Vendoring wasm-bindgen-macro v0.2.76 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/wasm-bindgen-macro-0.2.76) to portmod-rust-2.1.0-vendor.tar.gz/wasm-bindgen-macro
   Vendoring wasm-bindgen-macro-support v0.2.76 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/wasm-bindgen-macro-support-0.2.76) to portmod-rust-2.1.0-vendor.tar.gz/wasm-bindgen-macro-support
   Vendoring wasm-bindgen-shared v0.2.76 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/wasm-bindgen-shared-0.2.76) to portmod-rust-2.1.0-vendor.tar.gz/wasm-bindgen-shared
   Vendoring winapi v0.3.9 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/winapi-0.3.9) to portmod-rust-2.1.0-vendor.tar.gz/winapi
   Vendoring winapi-i686-pc-windows-gnu v0.4.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/winapi-i686-pc-windows-gnu-0.4.0) to portmod-rust-2.1.0-vendor.tar.gz/winapi-i686-pc-windows-gnu
   Vendoring winapi-util v0.1.5 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/winapi-util-0.1.5) to portmod-rust-2.1.0-vendor.tar.gz/winapi-util
   Vendoring winapi-x86_64-pc-windows-gnu v0.4.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/winapi-x86_64-pc-windows-gnu-0.4.0) to portmod-rust-2.1.0-vendor.tar.gz/winapi-x86_64-pc-windows-gnu
   Vendoring wyz v0.2.0 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/wyz-0.2.0) to portmod-rust-2.1.0-vendor.tar.gz/wyz
   Vendoring yaml-rust v0.4.5 (/build/source/cargo-home.qFI/registry/src/github.com-1ecc6299db9ec823/yaml-rust-0.4.5) to portmod-rust-2.1.0-vendor.tar.gz/yaml-rust
To use vendored sources, add this to your .cargo/config.toml for this project:
installing
post-installation fixup
You changed the checksum of the source of the portmod-rust derivation.
But since the main derivation is also a fixed-output derivation (FOD), you need to update its cargoHash attribute too.
You can just use the hash Nix calculated here
to replace the old cargoHash value.
Thanks for your reply. Maybe you can clarify this for me. Where does that expected value come from? In the default.nix file, the cargoHansh value is sha256-tAghZmlg34jHr8gtNgL3MQ8EI7K6/TfDcTbBjxdWLr0=, which matches neither the wanted or got values in the error.
EDIT: Ok. I see what you meant. I switched cargoHash to cargoSha256 and was able to get past the issue. I found the info I was looking for: NixOS - Nixpkgs 21.11 manual
