Headphones appear as unplugged and microphone doesn't work
Hi,
I have a Minisforum AI X1 255 and when I plug the headset jack the system does not detect that these have been plugged in. No sounds comes out of them and the microphone does not work either. Opening the Plasma sounds settings which are set to “Analog Stereo Duplex” I can only see the speakers and internal microphone. The Headphones options shows as “unplugged” even after plugging them in. This system uses flakes for disko, home-manager and plasma-manager, should this be relevant.
My configuration below for the audio part, as per defaults on a previous NixOS assisted installation.
  # Enable sound with pipewire.
  services.pulseaudio.enable = false;
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
The result of lspci -vv for the sound part:
4:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Radeon High Definition Audio Controller (prog-if 00 [HDA compatible])
        Subsystem: Device 1f4c:b022
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin B routed to IRQ 109
        IOMMU group: 17
        Region 0: Memory at dc588000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [48] Vendor Specific Information: Len=08 <?>
        Capabilities: [50] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1+,D2+,D3hot+,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [64] Express (v2) Legacy Endpoint, IntMsgNum 0
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- TEE-IO-
                DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt- FltModeDis-
                LnkSta: Speed 16GT/s, Width x16
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR-
                         10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt+ EETLPPrefix+, MaxEETLPPrefixes 1
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
                         AtomicOpsCtl: ReqEn+
                         IDOReq- IDOCompl- LTR- EmergencyPowerReductionReq-
                         10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
                         EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported, FltMode-
        Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fee00000  Data: 0000
        Capabilities: [100 v1] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
        Capabilities: [2a0 v1] Access Control Services
                ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
Any idea of what I can do to have this working? Thank you in advance.
Further searching shows that this is a known issue on other models of this AI series GitHub - puffo/minisforum-audio-fix · GitHub
Is there any way for this to make its way into NixOS?
Seems like something for Issues · NixOS/nixos-hardware · GitHub.
This shouldn’t be hard to try out yourself, though. You can package the etc/modprobe.d and lib/firmware parts of this solution in a small derivation in your local configuration, add the whole thing to hardware.firmware, use the modprobe.d file in that package for environment.etc."modprobe.d/alc245-jack.conf".source, and then all you’ll be missing is that unmute hack — for NixOS, I would DIY it, if you need it, as a systemd user service.
Thanks for your recommendation. I will post this on nixos-hardware.
Unfortunately, I don’t have the technical knowledge to follow through with your suggestion to do it myself…
I shall close the topic now.
Link to nixos-hardware issue for anyone stumbling on this Minisforum AI X1 255: Headphones appear as unplugged and microphone doesn’t work · Issue #1829 · NixOS/nixos-hardware · GitHub
