Hi all,
Noob here. Started using Nix very recently on my Debian instalation, and been slowly moving from Debian packages to Nix packages where I can/it makes sense. The plan is to eventually move to NixOS, and so I’m now trying to learn how to build projects.
My first goal project is rqlite. I’ve read through “Writing Nix Expressions”, and now I’m reading the Nixpkgs section on Go and the wiki. I copied the example over from the Nixpkgs manual and adapted it to this:
{ buildGoModule, fetchFromGitHub, lib }:
buildGoModule rec {
name = "rqlite";
version = "7.3.2";
src = fetchFromGitHub {
owner = "rqlite";
repo = "rqlite";
rev = "v${version}";
sha256 = "sha256-C0S+zOCdWnUcbrpQeV4dK1n67GrAiYOJJv7VKoEQgUs=";
vendorSha256 = "sha256-Kr1Ug3zuSCeBucz0zpcouYfU0xKGmi0wi9Kh8+adHD4=";
runVend = false;
meta = with lib; {
description = "The lightweight, distributed relational database built on SQLite";
homepage = "http://www.rqlite.io";
license = licenses.mit;
platforms = platforms.linux ++ platforms.darwin;
However, when building with nix-build -E 'with import <nixpkgs> {}; callPackage ./default.nix {}'
it eventually gives this error:
[http] 2022/03/02 23:16:30 HTTP service Serve() returned: accept tcp 127.0.0.1:33149: use of closed network connection
--- PASS: Test_MultiNodeClusterBootstrapLaterJoinHTTPS (2.15s)
=== RUN Test_MultiNodeClusterRaftAdv
--- FAIL: Test_MultiNodeClusterRaftAdv (0.00s)
panic: couldn't find a local IPv4 address [recovered]
goroutine 846 [running]:
testing.tRunner.func1.2({0xafe4c0, 0xc981b0})
testing/testing.go:1209 +0x24e
testing.tRunner.func1()
testing/testing.go:1212 +0x218
panic({0xafe4c0, 0xc981b0})
runtime/panic.go:1038 +0x215
github.com/rqlite/rqlite/system_test.mustGetLocalIPv4Address()
github.com/rqlite/rqlite/system_test/helpers.go:665 +0xdc
github.com/rqlite/rqlite/system_test.Test_MultiNodeClusterRaftAdv(0xc0006e8000)
github.com/rqlite/rqlite/system_test/cluster_test.go:518 +0x158
testing.tRunner(0xc0006e8000, 0xbfb1f0)
testing/testing.go:1259 +0x102
created by testing.(*T).Run
testing/testing.go:1306 +0x35a
FAIL github.com/rqlite/rqlite/system_test 26.712s
FAIL
error: builder for '/nix/store/jfcmih3wa0iy0rs4052131qba5xqvx0l-rqlite.drv' failed with exit code 1
Apparently, this is from some rqlite test, but I’m wondering if it’s not because of something I’m doing wrong on the Nix side.
Some of the relevant Nix related info:
$ nix-env --version
nix-env (Nix) 2.6.1
$ nix-channel --list
nixpkgs https://nixos.org/channels/nixpkgs-unstable
$ nix-instantiate --eval -E '(import <nixpkgs> {}).lib.version'
"22.05pre357729.22dc22f8ced"
For comparison I also looked at the default.nix
file for Syncthing and Gotify, but at least to my untrained eyes there’s no significant difference.
Any help would be much appreciated!
