Help Compiling own LLVM
It’s been a journey. I’m developing passes for LLVM, so I need the source + compiled version of clang in my machine. Following the wiki proved to be outdated, and I’ve been solving on issue at a time from that method. Initially we are to:
  1. Clone the llvm-project repo, I use the version 22 branch and depth flag to spare some disk:
[bernborgess@e14:~/test]$ git clone https://github.com/llvm/llvm-project \
      --depth=1 --branch=release/22.x
  1. Insert the shell.nix from the wiki
  2. Enter the shell
[bernborgess@e14:~/test]$ nix-shell
evaluation warning: 'targetPlatform' has been renamed to/replaced by 'stdenv.targetPlatform'
[nix-shell:~/test]$
  1. Create build directory and configure with cmake, using the shell’s flags
[nix-shell:~/test]$ mkdir build && cd build && cmake $cmakeFlags ../llvm-project/llvm
First error I found is:
GCC_INSTALL_PREFIX is deprecated and will be removed
We just remove this flag. Then starting compilation complaigns:
LIBCXXABI_USE_LLVM_UNWINDER is set to ON, but libunwind is not specified in
LLVM_ENABLE_RUNTIMES.
Then I add libunwind to the flags but then we get the error
Compiler doesn’t support generation of unwind tables if exception support is
disabled. Building libunwind DSO with runtime dependency on C++ ABI library
is not supported.
Guess I’ll try to turn it OFF then!
-DLIBCXXABI_USE_LLVM_UNWINDER=OFF
Now at last, I’m building with all the modifications but I get this error at the end:
/nix/store/p2vkw5s89ff1fs2d2rxqxiqil9s0jpcm-binutils-2.46/bin/ld.bfd: cannot find crti.o: No such file or directory
/nix/store/p2vkw5s89ff1fs2d2rxqxiqil9s0jpcm-binutils-2.46/bin/ld.bfd: cannot find crtbeginS.o: No such file or directory
clang++: error: linker command failed with exit code 1 (use -v to see invocation)
I would like help understanding THIS, why does it fail at linking? Why is it using clang++, given I specified to use g++? Messing with the $LIBRARY env var didn’t help. For reference this is the final shell.nix I ended up working with:
with import <nixpkgs> {};
  gccForLibs = stdenv.cc.cc;
in stdenv.mkDerivation {
  name = "llvm-env";
  buildInputs = [
    bashInteractive
    python3
    ninja
    cmake
    llvmPackages_latest.llvm
  NIX_LDFLAGS="-L${gccForLibs}/lib/gcc/${targetPlatform.config}/${gccForLibs.version} ";
  CFLAGS="-B${gccForLibs}/lib/gcc/${targetPlatform.config}/${gccForLibs.version} -B ${stdenv.cc.libc}/lib";
  LIBRARY_PATH="${stdenv.cc.libc}/lib";
  cmakeFlags = [
    #"-DGCC_INSTALL_PREFIX=${gcc}"  GCC_INSTALL_PREFIX is deprecated and will be removed.
    "-DCMAKE_C_COMPILER=${gcc}/bin/gcc" # Added these explicitly
    "-DCMAKE_CXX_COMPILER=${gcc}/bin/g++"
    "-DC_INCLUDE_DIRS=${stdenv.cc.libc.dev}/include"
    "-GNinja"
    "-DCMAKE_BUILD_TYPE=Release"
    "-DCMAKE_INSTALL_PREFIX=../inst"
    "-DLLVM_INSTALL_TOOLCHAIN_ONLY=ON"
    "-DLLVM_ENABLE_PROJECTS=clang"
    "-DLLVM_ENABLE_RUNTIMES=libcxx;libcxxabi"
    "-DLIBCXXABI_USE_LLVM_UNWINDER=OFF" # Disabled this feature
    "-DLLVM_TARGETS_TO_BUILD=host"
Also, After this issue is fixed, I’ll be updating the wiki for the current working way to do this, so help is VERY MUCH appreciated!
Also, this issue looks very similar. With this info, I just have to figure out how to pass --gcc-install-dir to the command.
