oxbar
1
Hello,
I have a Kabylake Card on my laptop…
I’ve never been able to get sound working on it… Normally all linux distro’s i’ve tried it uses sof-firmware…
Looked throuh this guide Sound not working updated to unstable and still no luck…
This is all the informaton i have right now… if you need more let me know
[joe@nixos:~]$ lspci -k |grep snd
Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_cnl
Thanks
What did you try? Share your sound and kernel config.
oxbar
3
Hi,
How do I get all that information… I would be glad to give it
573
4
as in the link you posted might be helpful, also the output of commands regarding info about your sound specifics.
This recent post investigated similar issues, using info sharing.
oxbar
5
Here is my configuration.nix
This is all i got!
Thanks
