Help installing first python application
I am attempting to install quickwall.
I have these two files:
default.nix
with import <nixpkgs> {};
pkgs.python3Packages.callPackage ./quickwal.nix {}
quickwal.nix
{ lib,
  buildPythonApplication,
  fetchPypi,
  setuptools
buildPythonApplication rec {
  pname = "QuickWall";
  version = "0.0.5";
  src = fetchPypi {
    inherit pname version;
    sha256 = "1qcayvbcv9jnfkp4q1rpdnlyxhzmg9dsldw8jvkq1f1r6kqpkglz";
  buildInputs = with import <nixpkgs> {};
    [pkgs.python39Packages.dbus-python];
  propagatedBuildInputs = [setuptools];
  meta = with lib; {
    description = "Set latest wallpapers from Unsplash from the commandline";
    homepage = "deepjyoti30.github.io/quickwall";
    license = licenses.mit;
When I run nix-build it gives me this:
ERROR: Could not find a version that satisfies the requirement dbus-python (from quickwall) (from versions: none)
ERROR: No matching distribution found for dbus-python
I tried specifying the dependency as a buildInput but that didn’t work.
Maybe you meant propagatedBuildInputs, but if not try putting dbus-python there.
Sure. I moved it to propagatedBuildInputs
{ lib,
  fetchPypi,
  setuptools
  version = "0.0.5";
  src = fetchPypi {
  propagatedBuildInputs = with import <nixpkgs> {};
    [pkgs.python39Packages.dbus-python setuptools];
  meta = with lib; {
Same error
Executing pipInstallPhase
/build/QuickWall-0.0.5/dist /build/QuickWall-0.0.5
Processing ./QuickWall-0.0.5-py3-none-any.whl
Do not use with here, drop importing <nixpkgs>, add dbus-python to the argset and then use the passed in version, to make sure you get the correct one built for and with exactly the python you are using.
As @NobbZ said, you should remove the with import <nixpkgs>.
When doing pkgs.python3Packages.callPackage ./quickwal.nix {} you’ll have the python3Packages namespace (?) at hand and can pick what you need from there.
Otherwise you may intermix python packages from different versions. Atm. python3 == python39, but what if python310 gets aliased to python3?
And by picking dependencies from the argset you’ll be able to change python versions (nearly) at will, i.e. pkgs.python310Packages.callPackage ./quickwal.nix {}.
Adopting the changes quickwall.nix may look like below, which builds. Though, I had to patch setup.py and remove the install_requires argument from setup(). Maybe a real nix-python-pro-packager could enlighten us, why this is necessary?
{ lib
, buildPythonPackage
, fetchPypi
, beautifulsoup4
, dbus-python
, downloader-cli
, pywal
, requests
, simber
buildPythonPackage rec {
  version = "0.0.5";
  src = fetchPypi {
    beautifulsoup4
    dbus-python
    downloader-cli
    pywal
    requests
    simber
  # XXX: Remove install_requires from setup(), as it triggers:
  #   Processing ./QuickWall-0.0.5-py3-none-any.whl
  #   ERROR: Could not find a version that satisfies the requirement dbus-python (from quickwall) (from versions: none)
  #   ERROR: No matching distribution found for dbus-python
  patchPhase = "sed -i '/install_requires/d' setup.py";
  # Need to disable checks. There're no tests atm, causing the build to fail.
  doCheck = false;
  meta = with lib; {
