Hi! I’m new to NixOS and really want to set up my system using a pre-made configuration, but I’m a bit confused.
I found this repository with configs:
https://github.com/librephoenix/nixos-config
I want to use this config to install NixOS, but I’m not sure where to start or how to properly apply it. I also need to install NVIDIA drivers (my GPU is an RTX 4060), and it looks like the config has something related to that — but I’m not sure if it’s set up correctly for my system.
My system specs:
- GPU: NVIDIA RTX 4060
- CPU: AMD Ryzen 5 5600
I’d really appreciate if someone could:
- Explain how to properly use the config from this repository for installation.
- Help me edit the config for my specific hardware, if needed.
- Make sure NVIDIA drivers are set up correctly, or help me do that.
I can provide output from lspci
, nix-info
, etc., if needed.
Thank you so much in advance
error
warning: Git tree '/home/yakatze/nixos-config' is dirty
warning: error: unable to download 'https://cache.nixos.org/nar/00qqq9km18qcqv016561ms0kpnsrwpw2xy9x1vnpdffndsa03nzd.nar.xz': HTTP error 200 (curl error: Failure when receiving data from the peer); retrying from offset 11919891 in 313 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1k8hizbxwwcy2wvgbpsd2cpacjf7c5sssc8pna2pjiq7cs0saac3.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 5801152 in 252 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1k8hizbxwwcy2wvgbpsd2cpacjf7c5sssc8pna2pjiq7cs0saac3.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 5878695 in 310 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1k8hizbxwwcy2wvgbpsd2cpacjf7c5sssc8pna2pjiq7cs0saac3.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 5709120 in 304 ms
warning: error: unable to download 'https://cache.nixos.org/nar/199xrbd3345w6mv65a7m8fa2d7ypdzjilmbbgrqjy32xxdxfxhbs.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 2621440 in 296 ms
warning: error: unable to download 'https://cache.nixos.org/nar/03q0yh9rjxdhj8q62v94v3nknvxv19nd35b889ngqcbxz15zipm0.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 1303266 in 278 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1msxk26zf7yfi7hgjfc94mlsks0928kqvh88r3vsai48wylcsl0l.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 991988 in 331 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0bb3wzkadxk85r4wcgifz6cnv5rhyi5r473nmzaj0wv07x3r80sn.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 802123 in 264 ms
warning: error: unable to download 'https://cache.nixos.org/nar/09npn8xzhy5zj7wcjcxax3zp8k82jq6x02d95cnxb6imixvmn8gp.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 773557 in 267 ms
warning: error: unable to download 'https://cache.nixos.org/nar/10r2b96nkkbs42hsxpl9y0qi8mz5c3mpbgv1hrp0xbmy5x8mib3c.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 540672 in 336 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0z3zvh66gjymw1h7a92kh690ph8s2x275nm5mp1dgqc4dhf7n7w5.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 393216 in 332 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1mgp4nb444niq0kpkgpmp7p6xcbaqhwmm47nvsk9wrb37v8fy3aq.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 180224 in 281 ms
warning: error: unable to download 'https://cache.nixos.org/nar/11xsmvv9wm7dbyigd1w1kr0h9ara39g2g7610s1yb8gvp3czk9kb.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 196608 in 328 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0q6rahd85l49yfw7q8ss6gphaiqfnb2ivkyv5ccrgwpbl9nb7dgv.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 147456 in 255 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0niffhvpk80hq2g7fdak6sxpyj7i1j91hdxqqf6dazk459pjkdwi.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 98196 in 322 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1iz8hzizr559f3znp6g08jdq49v90s3zwdrfqlfpxyqhb5il47x6.nar.xz': HTTP error 200 (curl error: Failed sending data to the peer); retrying from offset 12591506 in 329 ms
warning: error: unable to download 'https://cache.nixos.org/nar/114apv1pj04h94lkilz1gc2xyj1h40fwr6p9mfy3bn7gidg127w3.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 6218150 in 269 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0wi0b2jk6n1sghsnws7r2v4c1dc854a6y6k183c1wdk8v52cr88s.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 20855421 in 277 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0zsnxw4pacl54hnwnjwkvsqqbzd3kr23b7cpfc2wbxsa7mdphcj4.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 20001964 in 291 ms
warning: error: unable to download 'https://cache.nixos.org/nar/02g46jykp6mygggvb6aas12znz774drmbf6qdnlh9n8ly33y25cv.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 19905228 in 292 ms
warning: error: unable to download 'https://cache.nixos.org/nar/10kgf3l6n15lx32hgcynnij28whnjifafa0v0xzkpwzrkswfpg2n.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 16967777 in 329 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1a3nzgs95q123dlkilk9kr5g4j5jklgy4w6vcpf3ns7cw7sjj0xs.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 6217705 in 298 ms
warning: error: unable to download 'https://cache.nixos.org/nar/080iqq3mwckkmrxh74hbq9d41f3f4w7ik3m8502m4hilax19lg6l.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 5758260 in 304 ms
warning: error: unable to download 'https://cache.nixos.org/nar/14zkxg0wpdwim4ars2y7x3nxn2vm7bvqv8zdrcqa6rzzch5ch8kn.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 2242864 in 333 ms
warning: error: unable to download 'https://cache.nixos.org/nar/15yc2xnh2c69x3bzr7kj25a41nha2810gzmn1a8ha97rln1q0l6k.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 1866621 in 344 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1mbvqni9m5s89ghmwvfwfqip9f9s4ycvjs4li603ig9s42nk92s3.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 566004 in 275 ms
warning: error: unable to download 'https://cache.nixos.org/nar/174858ssiv9axabddcbplyqad4rl1ba097nnlqlfalqij8qp91f6.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 287476 in 288 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1azjrv87p2vnajnfjhlwicb701lhd2sp3fqqbafiaikbv2q6pmxc.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 262144 in 283 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1sb6xmd6q9glqm2dv9mggkjckmwy0pxgxq4fa0dg4pw5lg0k45sk.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 263025 in 329 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1iz8hzizr559f3znp6g08jdq49v90s3zwdrfqlfpxyqhb5il47x6.nar.xz': HTTP error 206 (curl error: Timeout was reached); retrying from offset 49324788 in 501 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1zqsrysf0vwwg7i536rzr0khm76rfrdrnwicnlcrcdklpgyglkmi.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 17206207 in 293 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0l0nfg451barzv3kv5f37hbw13ka2fvmxxdvbjjpkjyx0ywsz54w.nar.xz': HTTP error 200 (curl error: Timeout was reached); retrying from offset 7307264 in 347 ms
warning: error: unable to download 'https://cache.nixos.org/nar/114apv1pj04h94lkilz1gc2xyj1h40fwr6p9mfy3bn7gidg127w3.nar.xz': Timeout was reached (28); retrying from offset 6218150 in 603 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1mbvqni9m5s89ghmwvfwfqip9f9s4ycvjs4li603ig9s42nk92s3.nar.xz': Timeout was reached (28); retrying from offset 566004 in 630 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0wi0b2jk6n1sghsnws7r2v4c1dc854a6y6k183c1wdk8v52cr88s.nar.xz': Timeout was reached (28); retrying from offset 20855421 in 689 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1azjrv87p2vnajnfjhlwicb701lhd2sp3fqqbafiaikbv2q6pmxc.nar.xz': Timeout was reached (28); retrying from offset 262144 in 540 ms
warning: error: unable to download 'https://cache.nixos.org/nar/174858ssiv9axabddcbplyqad4rl1ba097nnlqlfalqij8qp91f6.nar.xz': Timeout was reached (28); retrying from offset 287476 in 696 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0zsnxw4pacl54hnwnjwkvsqqbzd3kr23b7cpfc2wbxsa7mdphcj4.nar.xz': Timeout was reached (28); retrying from offset 20001964 in 512 ms
warning: error: unable to download 'https://cache.nixos.org/nar/02g46jykp6mygggvb6aas12znz774drmbf6qdnlh9n8ly33y25cv.nar.xz': Timeout was reached (28); retrying from offset 19905228 in 570 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1a3nzgs95q123dlkilk9kr5g4j5jklgy4w6vcpf3ns7cw7sjj0xs.nar.xz': Timeout was reached (28); retrying from offset 6217705 in 612 ms
warning: error: unable to download 'https://cache.nixos.org/nar/080iqq3mwckkmrxh74hbq9d41f3f4w7ik3m8502m4hilax19lg6l.nar.xz': Timeout was reached (28); retrying from offset 5758260 in 677 ms
warning: error: unable to download 'https://cache.nixos.org/nar/10kgf3l6n15lx32hgcynnij28whnjifafa0v0xzkpwzrkswfpg2n.nar.xz': Timeout was reached (28); retrying from offset 16967777 in 640 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1sb6xmd6q9glqm2dv9mggkjckmwy0pxgxq4fa0dg4pw5lg0k45sk.nar.xz': Timeout was reached (28); retrying from offset 263025 in 526 ms
warning: error: unable to download 'https://cache.nixos.org/nar/14zkxg0wpdwim4ars2y7x3nxn2vm7bvqv8zdrcqa6rzzch5ch8kn.nar.xz': Timeout was reached (28); retrying from offset 2242864 in 559 ms
warning: error: unable to download 'https://cache.nixos.org/nar/15yc2xnh2c69x3bzr7kj25a41nha2810gzmn1a8ha97rln1q0l6k.nar.xz': Timeout was reached (28); retrying from offset 1866621 in 518 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1zqsrysf0vwwg7i536rzr0khm76rfrdrnwicnlcrcdklpgyglkmi.nar.xz': Timeout was reached (28); retrying from offset 17206207 in 535 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0l0nfg451barzv3kv5f37hbw13ka2fvmxxdvbjjpkjyx0ywsz54w.nar.xz': Timeout was reached (28); retrying from offset 7307264 in 506 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1iz8hzizr559f3znp6g08jdq49v90s3zwdrfqlfpxyqhb5il47x6.nar.xz': Timeout was reached (28); retrying from offset 49324788 in 1048 ms
warning: error: unable to download 'https://cache.nixos.org/nar/114apv1pj04h94lkilz1gc2xyj1h40fwr6p9mfy3bn7gidg127w3.nar.xz': Timeout was reached (28); retrying from offset 6218150 in 1086 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1mbvqni9m5s89ghmwvfwfqip9f9s4ycvjs4li603ig9s42nk92s3.nar.xz': Timeout was reached (28); retrying from offset 566004 in 1215 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0wi0b2jk6n1sghsnws7r2v4c1dc854a6y6k183c1wdk8v52cr88s.nar.xz': Timeout was reached (28); retrying from offset 20855421 in 1324 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0zsnxw4pacl54hnwnjwkvsqqbzd3kr23b7cpfc2wbxsa7mdphcj4.nar.xz': Timeout was reached (28); retrying from offset 20001964 in 1165 ms
warning: error: unable to download 'https://cache.nixos.org/nar/15yc2xnh2c69x3bzr7kj25a41nha2810gzmn1a8ha97rln1q0l6k.nar.xz': Timeout was reached (28); retrying from offset 1866621 in 1206 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1sb6xmd6q9glqm2dv9mggkjckmwy0pxgxq4fa0dg4pw5lg0k45sk.nar.xz': Timeout was reached (28); retrying from offset 263025 in 1245 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1azjrv87p2vnajnfjhlwicb701lhd2sp3fqqbafiaikbv2q6pmxc.nar.xz': Timeout was reached (28); retrying from offset 262144 in 1358 ms
warning: error: unable to download 'https://cache.nixos.org/nar/14zkxg0wpdwim4ars2y7x3nxn2vm7bvqv8zdrcqa6rzzch5ch8kn.nar.xz': Timeout was reached (28); retrying from offset 2242864 in 1121 ms
warning: error: unable to download 'https://cache.nixos.org/nar/02g46jykp6mygggvb6aas12znz774drmbf6qdnlh9n8ly33y25cv.nar.xz': Timeout was reached (28); retrying from offset 19905228 in 1250 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1a3nzgs95q123dlkilk9kr5g4j5jklgy4w6vcpf3ns7cw7sjj0xs.nar.xz': Timeout was reached (28); retrying from offset 6217705 in 1290 ms
warning: error: unable to download 'https://cache.nixos.org/nar/10kgf3l6n15lx32hgcynnij28whnjifafa0v0xzkpwzrkswfpg2n.nar.xz': Timeout was reached (28); retrying from offset 16967777 in 1299 ms
warning: error: unable to download 'https://cache.nixos.org/nar/080iqq3mwckkmrxh74hbq9d41f3f4w7ik3m8502m4hilax19lg6l.nar.xz': Timeout was reached (28); retrying from offset 5758260 in 1171 ms
warning: error: unable to download 'https://cache.nixos.org/nar/174858ssiv9axabddcbplyqad4rl1ba097nnlqlfalqij8qp91f6.nar.xz': Timeout was reached (28); retrying from offset 287476 in 1379 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1zqsrysf0vwwg7i536rzr0khm76rfrdrnwicnlcrcdklpgyglkmi.nar.xz': Timeout was reached (28); retrying from offset 17206207 in 1225 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0l0nfg451barzv3kv5f37hbw13ka2fvmxxdvbjjpkjyx0ywsz54w.nar.xz': Timeout was reached (28); retrying from offset 7307264 in 1194 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1iz8hzizr559f3znp6g08jdq49v90s3zwdrfqlfpxyqhb5il47x6.nar.xz': Timeout was reached (28); retrying from offset 49324788 in 2096 ms
warning: error: unable to download 'https://cache.nixos.org/nar/114apv1pj04h94lkilz1gc2xyj1h40fwr6p9mfy3bn7gidg127w3.nar.xz': Timeout was reached (28); retrying from offset 6218150 in 2038 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1mbvqni9m5s89ghmwvfwfqip9f9s4ycvjs4li603ig9s42nk92s3.nar.xz': Timeout was reached (28); retrying from offset 566004 in 2435 ms
warning: error: unable to download 'https://cache.nixos.org/nar/14zkxg0wpdwim4ars2y7x3nxn2vm7bvqv8zdrcqa6rzzch5ch8kn.nar.xz': Timeout was reached (28); retrying from offset 2242864 in 2227 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0zsnxw4pacl54hnwnjwkvsqqbzd3kr23b7cpfc2wbxsa7mdphcj4.nar.xz': Timeout was reached (28); retrying from offset 20001964 in 2430 ms
warning: error: unable to download 'https://cache.nixos.org/nar/15yc2xnh2c69x3bzr7kj25a41nha2810gzmn1a8ha97rln1q0l6k.nar.xz': Timeout was reached (28); retrying from offset 1866621 in 2131 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0wi0b2jk6n1sghsnws7r2v4c1dc854a6y6k183c1wdk8v52cr88s.nar.xz': Timeout was reached (28); retrying from offset 20855421 in 2321 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1sb6xmd6q9glqm2dv9mggkjckmwy0pxgxq4fa0dg4pw5lg0k45sk.nar.xz': Timeout was reached (28); retrying from offset 263025 in 2738 ms
warning: error: unable to download 'https://cache.nixos.org/nar/02g46jykp6mygggvb6aas12znz774drmbf6qdnlh9n8ly33y25cv.nar.xz': Timeout was reached (28); retrying from offset 19905228 in 2305 ms
warning: error: unable to download 'https://cache.nixos.org/nar/080iqq3mwckkmrxh74hbq9d41f3f4w7ik3m8502m4hilax19lg6l.nar.xz': Timeout was reached (28); retrying from offset 5758260 in 2155 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1azjrv87p2vnajnfjhlwicb701lhd2sp3fqqbafiaikbv2q6pmxc.nar.xz': Timeout was reached (28); retrying from offset 262144 in 2653 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1a3nzgs95q123dlkilk9kr5g4j5jklgy4w6vcpf3ns7cw7sjj0xs.nar.xz': Timeout was reached (28); retrying from offset 6217705 in 2135 ms
warning: error: unable to download 'https://cache.nixos.org/nar/10kgf3l6n15lx32hgcynnij28whnjifafa0v0xzkpwzrkswfpg2n.nar.xz': Timeout was reached (28); retrying from offset 16967777 in 2064 ms
warning: error: unable to download 'https://cache.nixos.org/nar/174858ssiv9axabddcbplyqad4rl1ba097nnlqlfalqij8qp91f6.nar.xz': Timeout was reached (28); retrying from offset 287476 in 2678 ms
warning: error: unable to download 'https://cache.nixos.org/nar/1zqsrysf0vwwg7i536rzr0khm76rfrdrnwicnlcrcdklpgyglkmi.nar.xz': Timeout was reached (28); retrying from offset 17206207 in 2513 ms
warning: error: unable to download 'https://cache.nixos.org/nar/0l0nfg451barzv3kv5f37hbw13ka2fvmxxdvbjjpkjyx0ywsz54w.nar.xz': Timeout was reached (28); retrying from offset 7307264 in 2173 ms
error: some substitutes for the outputs of derivation '/nix/store/qgj7jvdwb42h72s9q93v1jn28mxzzjdi-linux-zen-6.14.4.drv' failed (usually happens due to networking issues); try '--fallback' to build derivation from source
warning: error: unable to download 'https://cache.nixos.org/nar/1y3b8yfaqrws4jb6c48h5rwsp1l736gyqac92wdm3cgk1krzpvc8.nar.xz': Failed sending data to the peer (55); retrying in 296 ms
error: 1 dependencies of derivation '/nix/store/aba47ial75iqmhfwm1lkkp83w9ihbl4f-nixos-system-desktop-25.05.20250503.7a2622e.drv' failed to build
