I’m trying to package ssh-chat. The packaging was not hard, just a standard call of buildGoModule
. ssh-chat being server side software, I also want to make a NixOS module for it. I’ve never written a NixOS module before, and there are some things I need help with. Here’s my current implementation of the module:
{ config, lib, pkgs, ... }:
with lib;
let cfg = config.services.ssh-chat;
options.services.ssh-chat = {
enable = mkEnableOption "Chat over SSH";
bind = mkOption {
default = "0.0.0.0:2022";
example = "0.0.0.0:22";
type = types.str;
description = "Host and port to listen on.";
admin = mkOption {
default = null;
example = "";
type = types.nullOr types.path;
description = "File of public keys who are admins.";
whitelist = mkOption {
default = null;
example = "";
description = "Optional file of public keys who are allowed to connect.";
motd = mkOption {
default = null;
example = "";
description = "Optional Message of the Day file.";
config = mkIf cfg.enable {
systemd.services.ssh-chat = {
description = "Chat over SSH";
after = [ "network-online.target" ];
serviceConfig = {
ExecStart = ''
${pkgs.ssh-chat}/bin/ssh-chat \
--identity=/etc/ssh/ssh_host_ed25519_key \
--bind=${cfg.bind} \
${if isNull cfg.admin then "\\" else "--admin=${cfg.admin} \\"}
${if isNull cfg.whitelist then "\\" else "--whitelist=${cfg.whitelist} \\"}
${if isNull cfg.motd then "\\" else "--motd=${cfg.motd} \\"}
Type = "simple";
DynamicUser = true;
Restart = "on-failure";
StartLimitBurst = 5;
My questions:
- How should I supply a default ssh identity file? Is it ok to read
? This would require using a sudo user to run ssh-chat. Or should I make a dedicated user for ssh-chat? How would I make sure the user has an ssh identity? - Should I prevent the ssh identity file from being copied to Nix store? How can I do this?
- Do I need other options for Systemd?
- ssh-chat can optionally save chat logs to a specified file. How can I make the logs readable to the system user if ssh-chat itself is run with another user?
- Any other suggestions/comments?
Any and all feedback would be much appreciated!
