I have latest neovim 0.5.0 from unstable channel in my systemPackages and a module with package = unstable.neovim.
When I run sudo nixos-rebuild switch it fails with this error:
building '/nix/store/xww7ac2zpqqgzy2xmkf4jkfwngg1fs2m-neovim-0.5.0.drv'...
Generating remote plugin manifest
building '/nix/store/qmmns1pwgqwci76maf5xn9rh6b93pyll-neovim-0.5.0.drv'...
substituteStream(): WARNING: pattern 'Name=Neovim' doesn't match anything in file '/nix/store/lg8kk3a1wi9dl54imrl04f544lszzysi-neovim-0.5.0/share/applications/nvim.desktop'
/nix/store/mnrankjvp65m4gr6yq92ghdd5i0mj9lc-hook/nix-support/setup-hook: line 40: /nix/store/5d7g5rvjl3ws9isln704sh8v33d9rq7p-neovim-0.5.0/bin/nvim-python3: Permission denied
builder for '/nix/store/qmmns1pwgqwci76maf5xn9rh6b93pyll-neovim-0.5.0.drv' failed with exit code 1
cannot build derivation '/nix/store/9zm6355qakvmfbdfqrrgc18w9lybq8pc-man-paths.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/gfdq1wmz5zpzlaggvl1jad2ashppp5aj-neovim-0.5.0_fish-completions.drv': 1 dependencies couldn't be built
cannot build derivation '/nix/store/nazlda8qr6ilbmi9r3vrbxh4pjhn3p29-system-path.drv': 1 dependencies couldn't be built
I’ve removed all references to neovim in my configuration.nix and home manager config, ran sudo nix-collect-garbage -d and updated the channels, then added the package back to systemPackages and ran sudo nixos-rebuild switch, but nothing changed.
I can install neovim using nix-env -iA unstable.neovim and it successfully works, but then I cannot manage plugins and etc trough the module.
I’m using NixOS 21.05 for only several weeks, any help would be appreciated
{ config, pkgs, ... }:
let unstable = import <nixos-unstable> {};
imports =
./hardware-configuration.nix
./cachix.nix
boot.loader.efi.efiSysMountPoint = "/boot/efi";
networking.hostName = "yakuri354-laptop";
time.timeZone = "Europe/Moscow";
networking.useDHCP = false;
networking.interfaces.wlp2s0.useDHCP = true;
# console = {
# font = "Lat2-Terminus16";
# keyMap = "us";
nix.autoOptimiseStore = true;
nix.gc = {
automatic = true;
dates = "weekly";
options = "--delete-older-than 30d";
nix.extraOptions = ''
binary-caches-parallel-connections = 12
services.dbus.packages = with pkgs; [ gnome3.dconf ];
services.xserver.displayManager.gdm.wayland = true;
services.xserver.desktopManager.gnome.enable = true;
services.xserver.layout = "ru";
services.xserver.xkbOptions = "eurosign:e";
security.rtkit.enable = true;
# Add PipeWire instead of Pulseaudio
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
# jack.enable = true;
#media-session.enable = true;
services.xserver.libinput.enable = true;
programs.fish.enable = true;
programs.fish.promptInit = ''
any-nix-shell fish --info-right | source
nix.trustedUsers = [ "root" "yakuri354" ];
users.users.yakuri354 = {
isNormalUser = true;
shell = pkgs.fish;
extraGroups = [ "wheel" ]; # Enable ‘sudo’ for the user.
programs.neovim = {
package = unstable.neovim;
viAlias = true;
vimAlias = true;
environment.variables.EDITOR = "vim";
nixpkgs.config.allowUnfree = true; # :sad:
# $ nix search wget
wget
curl
git
clang
nano
neovim
powertop
cachix
unstable.any-nix-shell
# started in user sessions.
# programs.mtr.enable = true;
# programs.gnupg.agent = {
# enable = true;
# enableSSHSupport = true;
# Enable the OpenSSH daemon.
# Open ports in the firewall.
system.stateVersion = "21.05"; # Did you read the comment?
