Hi,
I’ve been a NixOS User for at least 4-5 months and I’ve recently started a little (homelab) project which requires installing nixos with
- ZFS
- Full Disk encryption
- UEFI Boot
I think I am almost done. Grub it’s working, password for decrypting the disk it’s working, systemd starts… Ok (few errors which I’m trying to recover through journalctl) and then I find myself in an empty terminal, which tells me I’m in systemd emergency mode.
I am pretty sure that the error in my configuration it’s in these few lines of code:
boot = {
supportedFilesystems = [ "zfs" ];
loader = {
systemd-boot.enable = true;
grub = {
version = 2;
device = "nodev";
efiSupport = true;
enableCryptodisk = true;
efi = {
canTouchEfiVariables = true;
efiSysMountPoint = "/boot";
kernelParams = [ "nohibernate" ];
initrd = {
luks.devices = {
root = {
device = "/dev/disk/by-uuid/91e9b387-f945-4466-8fa0-2a9bce81fa97";
preLVM = true;
Could you help me out with this problem? thanks a lot
N.B.
- The rest of the configuration.nix it’s correct, since it’s what I’ve used with close-to-0 modifications on my main PC ant several VMs. So the errors are there.
In case you find a working Uefi-zfs-luks compatible nixos config, that would help a lot.
I managed to figure out something more about my current problem… so, I have /dev/sda3 luks encrypted → /dev/mapper/cryptroot
then, I created a zfs pool on cryptroot → rpool
and then i did
zfs create -o mountpoint=legacy rpool/root
zfs create -o mountpoint=legacy rpool/root/nixos
zfs create -o mountpoint=legacy rpool/home
zfs create -o mountpoint=legacy rpool/var
(all that after creating their respective directories)
Problems
Those are all the errors I could get during the boot phase
[FAILED] Failed to start Remount Root and Kernel File Systems.
See 'systemctl status systemd-remount-fs.service' for details
systemd [1] failed to mount /home
[FAILED] Failed to mount /home
See 'systemctl status home.mount' for details
[DEPEND] Dependency failed for Local File Systems.
Example of my hardware-config.nix
{ config, lib, pkgs, modulesPath, ... }:
imports =
[ (modulesPath + "/installer/scan/not-detected.nix")
boot.initrd.availableKernelModules = [ "xhci_pci" "ahci" "nvme" "usb_storage" "usbhid" "sd_mod" ];
boot.kernelModules = [ "kvm-amd" ];
boot.extraModulePackages = [ ];
fileSystems."/" =
{ device = "rpool/root/nixos";
fsType = "zfs";
fileSystems."/home" =
{ device = "rpool/home";
fsType = "zfs";
options = [ "zfsutil" ];
fileSystems."/var" =
{ device = "rpool/var";
fsType = "zfs";
fileSystems."/boot" =
{ device = "/dev/disk/by-uuid/C632-2B34";
fsType = "vfat";
swapDevices =
[ { device = "/dev/disk/by-uuid/4110c69c-c13b-442e-94a7-57c46667dc6e"; }
hardware.cpu.amd.updateMicrocode = lib.mkDefault config.hardware.enableRedistributableFirmware;
Systemctl status home.mount
Loaded: /etc/fstab (generated)
Active: failed (Result: exit-code)
Where: /home
What: rpool/home
filesystem 'rpool/home' cannot be mounted using zfs-mount
use 'zfs set mountpoint=/home' or 'mount -t zfs rpool/home /home'
see zfs(8) for more information.
Systemctl status system-remount-fs
Loaded: loaded (/etc/systemd/system/system-remount-fs.service; enabled-runtime; vendor preset: enabled)
Drop-In: /nix/store/44789...1nsg-system-units/systemd-remount-fs.service.d
|-overrides.conf
filesystem 'rpool/root/nixos' cannot be mounted using zfs-mount
use 'zfs set mountpoint=/' or 'mount -t zfs rpool/root/nixos /'
