Hello. I tried overriding k9s with this
k9s = super.k9s.overrideAttrs (oldAttrs: rec {
version = "0.25.18";
src = super.fetchFromGitHub {
owner = "derailed";
repo = "k9s";
rev = "v${version}";
sha256 = "sha256-iUhMPtFX7qFULegiyhlT4aG9q3deZ8aRqyEcbZ9jY/s=";
But I get this error
error: builder for '/nix/store/s7gjc42qp9sb7vwn5kn2xn2nwwsqfyf6-k9s-0.25.18.drv' failed with exit code 1;
last 10 log lines:
> k8s.io/utils@v0.0.0-20220728103510-ee6ede2d64ed: is marked as explicit in vendor/modules.txt, but not explicitly required in go.mod
> oras.land/oras-go@v1.2.0: is marked as explicit in vendor/modules.txt, but not explicitly required in go.mod
> sigs.k8s.io/json@v0.0.0-20220713155537-f223a00ba0e2: is marked as explicit in vendor/modules.txt, but not explicitly required in go.mod
> sigs.k8s.io/kustomize/api@v0.12.1: is marked as explicit in vendor/modules.txt, but not explicitly required in go.mod
> sigs.k8s.io/kustomize/kyaml@v0.13.9: is marked as explicit in vendor/modules.txt, but not explicitly required in go.mod
> sigs.k8s.io/structured-merge-diff/v4@v4.2.3: is marked as explicit in vendor/modules.txt, but not explicitly required in go.mod
> To ignore the vendor directory, use -mod=readonly or -mod=mod.
> To sync the vendor directory, run:
> go mod vendor
For full logs, run 'nix log /nix/store/s7gjc42qp9sb7vwn5kn2xn2nwwsqfyf6-k9s-0.25.18.drv'.
error: 1 dependencies of derivation '/nix/store/19bna7pg0bm0chfnvjs9kiinh5n7c6w4-nix-shell-env.drv' failed to build
