Help patching a cursor theme
I’m trying to patch simp1e-cursors (nix package source, upstream) to add some in-between sizes.
This means I need to change the file sizes.txt.
Presently this is my overlay setup:
  addPatches =
    pkg: patches:
    pkg.overrideAttrs (oldAttrs: {
      patches = (oldAttrs.patches or [ ]) ++ patches;
  additions = final: _prev: import ../packages final.pkgs;
  modifications = final: prev: {
    foot = addPatches prev.foot [ ./foot-ctrl-c.patch ];
    simp1e-cursors =  addPatches prev.simp1e-cursors [ ./simp1e-sizes.patch ];
with the following simp1e-sizes.patch:
--- a/sizes.txt
+++ b/sizes.txt
@@ -1,1 +1,1 @@
-24,32,48,72
+24,26,28,30,32,48,72
This doesn’t work, after the rebuild has finished I can cat /nix/store/83...98-source/sizes.txt and it hasn’t changed.
I also tried
    simp1e-cursors = prev.simp1e-cursors.overrideAttrs (old: {
      prePatch = ''
        substituteInPlace sizes.txt \
            --replace-{fail,warn,quiet} '24,32,48,72' '24,26,28,30,32,48,72'
        cat sizes.txt
        exit 1
but that told me there wasn’t any matching text:
last 5 log lines:
       > Running phase: unpackPhase
       > unpacking source archive /nix/store/83r3w27bm4raalxam26xw9vbsz1bg098-source
       > source root is source
       > Running phase: patchPhase
       > substituteStream() in derivation simp1e-cursors-20250223: ERROR: pattern --replace-warn doesn't match anything in file 'sizes.txt'
I also tried the previous method with
      prePatch = ''
        rm sizes.txt
        echo  24,26,28,30,32,48,72 > sizes.txt
Where am I going wrong? Any help appreciated!
I was being dumb, it totally works!
